Stock cam and lifter package recommendation for stock 440+6
#2750737
03/10/20 12:40 PM
03/10/20 12:40 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
Rebuilding a stock 440 six pack engine. It's been a number of years since I did this and I recall the mopar performance stuff was junk. What manufacturer and camshaft are you engine guys using for a stock rebuild? I would even consider a step or 2 hotter, but want to keep stock exhaust and decent vacuum.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Stock cam and lifter package recommendation for stock 440+6
[Re: RSI700VIPER]
#2750780
03/10/20 03:45 PM
03/10/20 03:45 PM
RapidRobert
one of the two Summit house brands
[Re: elmor353]
#2750831
03/10/20 09:25 PM
03/10/20 09:25 PM
Posts: 643 southern conn
1969gtx
southern conn
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: elmor353]
#2750914
03/11/20 08:44 AM
03/11/20 08:44 AM
Posts: 3,916 usa
lewtot184
usa
I second RR's suggestion of Summit Racing's cams. I have both cams and love them. I use the smaller cam in my pickup with an auto, stock convertor and 3.23 gears. It runs great. I use the bigger cam in a 66 b-body with factory high stall convertor, 3.55 gears. The specs are .445/.465 lift, 214/224 duration @.050 for the small cam and .466/.488 lift, 224/234 duration @.050 for the larger. They both have excellent street manners. The larger cam has a slight lope at idle and pulls hard in a 440 with 9.2 compression, 452 heads and factory intake. A little more compression, better heads and intake would really wake it up. this has been my experience. I would look no further than the 6401 cam with good lifters and crane 99839 springs.
[Re: elmor353]
#2751065
03/11/20 05:38 PM
03/11/20 05:38 PM
RSI700VIPER
NW New Jersey
Appreciate all the feedback. Thanks!
[Re: 62maxwgn]
#2751207
03/12/20 10:58 AM
03/12/20 10:58 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I went with the Lunati 60302 cam in my wife's 440 six Pack Challenger. https://www.summitracing.com/parts/lun-60302Fresh rebuilt 440 engine with Stealth aluminum heads and stock Six Pack setup. Mild Daaco HP converter and 3.23 rear. Engine is a great cruiser, lots of low and mid range power with great vacuum.
[Re: KillerBee]
#2751235
03/12/20 12:20 PM
03/12/20 12:20 PM
Posts: 823 On the open road
Hrtbkr
On the open road
I second that Lunati cam. It's in my '71 GTX with a six barrel. "Mini Mayhem"-love what they call it.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: RSI700VIPER]
#2751254
03/12/20 01:05 PM
03/12/20 01:05 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Maybe Crower 271HDP. Allmost the same to the Lunati suggested but a bit more Exhaust duration and bit more Intake lift. I'm using 282HDP and is just a bit lumpy but plenty for a street car with A/C ( allmost street values on good vacuum and iddle ). So I think one step lower will be more stockish iddle if you want that
[Re: Pacnorthcuda]
#2751262
03/12/20 01:37 PM
03/12/20 01:37 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
I installed a Hughes HEH 1928 BL . Very happy with it, Stock manifolds, 9.14:1 CR with quench pistons, 3.55 gears, 727, 6 bbl carbs. CR is a critical parameter when selecting a Camshaft. Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
