Cold Roller Rocker adjustment ?? #2740019
02/05/20 03:49 PM
02/05/20 03:49 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Hey Guy's I know this has been discussed before but I have to ask. I have a small block LA engine with a .652 lift roller cam. The Cam Mfg says .23 adjustment. That really seems a little loose but ?? What would you suggest as a cold roller rocker adjustment to get close to the .23 when hot ??
6.50 @105.26
Re: Cold Roller Rocker adjustment ?? [Re: Kindafast] #2740020
02/05/20 03:51 PM
02/05/20 03:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you have aluminum heads I would try .017 and see how that works. I read on here somewhere years ago that .006 was the number to tighten up for aluminum heads cold. Seemed to work OK on my old 360.
68 Barracuda Formula S 340
Re: Cold Roller Rocker adjustment ?? [Re: Bad340fish] #2740021
02/05/20 03:54 PM
02/05/20 03:54 PM
Seaford, Va
Seaford, Va
Thanks , I do have 360-1 aluminum heads on it.
6.50 @105.26
Re: Cold Roller Rocker adjustment ?? [Re: Kindafast] #2740106
02/05/20 07:59 PM
02/05/20 07:59 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Aluminum head, iron block .005" tighter than spec cold is a good starting point.
Doug
Re: Cold Roller Rocker adjustment ?? [Re: dvw] #2740135
02/05/20 08:58 PM
02/05/20 08:58 PM
New York, USA
Chargerfan68 Offline
New York, USA
On my friend’s motor that we just dyno’d, after break-in and running all out, we checked it hot and we discovered it was .010” diff cold to hot. This was indy alum heads with iron block.
Re: Cold Roller Rocker adjustment ?? [Re: Kindafast] #2740166
02/05/20 10:37 PM
02/05/20 10:37 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
A little loose? At .23 I would say so. you miss typed and the setting should probably be .023. I would try the .006 number a .017 feeler gauge too set cold.
Re: Cold Roller Rocker adjustment ?? [Re: Kindafast] #2740178
02/05/20 10:59 PM
02/05/20 10:59 PM
I would set the lash at .006 tighter than the cam cards call for hot with the motor at room temps and then make sure and check it after breaking in the cam with the motor hot twocents
I've used that for a lot of motors but I don't think I have done that with SB with aluminum heads confused
Please let us know what you find out up
Re: Cold Roller Rocker adjustment ?? [Re: Cab_Burge] #2740214
02/06/20 07:26 AM
02/06/20 07:26 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My check of cold valves after they had been set at .018" lash hot on the dyno averaged .012" for intakes and .010" for exhausts. IIRC, that's about. 002" looser with the Victors than what I found with my old Stage VIs, so there are some variables in play here.
Re: Cold Roller Rocker adjustment ?? [Re: BradH] #2740216
02/06/20 08:01 AM
02/06/20 08:01 AM
Seaford, Va
Seaford, Va
Thanks guys , I appreciate the advice and info..
6.50 @105.26
