Cold Roller Rocker adjustment ??
#2740019
02/05/20 03:49 PM
02/05/20 03:49 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey Guy's I know this has been discussed before but I have to ask. I have a small block LA engine with a .652 lift roller cam. The Cam Mfg says .23 adjustment. That really seems a little loose but ?? What would you suggest as a cold roller rocker adjustment to get close to the .23 when hot ??
6.50 @105.26
Re: Cold Roller Rocker adjustment ??
[Re: Kindafast]
#2740020
02/05/20 03:51 PM
02/05/20 03:51 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
If you have aluminum heads I would try .017 and see how that works. I read on here somewhere years ago that .006 was the number to tighten up for aluminum heads cold. Seemed to work OK on my old 360.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2740021
02/05/20 03:54 PM
02/05/20 03:54 PM
Kindafast
Seaford, Va
Thanks , I do have 360-1 aluminum heads on it.
6.50 @105.26
[Re: dvw]
#2740135
02/05/20 08:58 PM
02/05/20 08:58 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
On my friend’s motor that we just dyno’d, after break-in and running all out, we checked it hot and we discovered it was .010” diff cold to hot. This was indy alum heads with iron block.
[Re: Kindafast]
#2740166
02/05/20 10:37 PM
02/05/20 10:37 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Hey Guy's I know this has been discussed before but I have to ask. I have a small block LA engine with a .652 lift roller cam. The Cam Mfg says .23 adjustment. That really seems a little loose but ?? What would you suggest as a cold roller rocker adjustment to get close to the .23 when hot ?? A little loose? At .23 I would say so. you miss typed and the setting should probably be .023. I would try the .006 number a .017 feeler gauge too set cold.
[Re: Kindafast]
#2740178
02/05/20 10:59 PM
02/05/20 10:59 PM
Posts: 43,225 Bend,OR USA
Cab_Burge
I would set the lash at .006 tighter than the cam cards call for hot with the motor at room temps and then make sure and check it after breaking in the cam with the motor hot I've used that for a lot of motors but I don't think I have done that with SB with aluminum heads Please let us know what you find out
[Re: BradH]
#2740216
02/06/20 08:01 AM
02/06/20 08:01 AM
Kindafast
Seaford, Va
Thanks guys , I appreciate the advice and info..
6.50 @105.26
