Gunk in oil fill tube on 2001 Durango with the 4.7 engine
#2739268
02/03/20 09:48 AM
02/03/20 09:48 AM
Posts: 90 Missouri
Citation_SP
Missouri
I have had this problem with my 2001 Durango since around 2007. Prior to 2007 the engine used no oil between oil changes however after 2007 the oil consumption went to 3 quarts between oil changes after the gunk appeared.
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine
[Re: burdar]
#2739442
02/03/20 09:28 PM
02/03/20 09:28 PM
Posts: 206 Paducah, KY USA Earth
jcruse64
My 01 Durango with the 4.7 did the same thing. I just assumed it was condensation mixing with oil vapor around the cap. I didn't notice any coolant leaks or excessive oil consumption. Same here with an '02 4.7 Durango.
[Re: NITROUSN]
#2739476
02/03/20 11:05 PM
02/03/20 11:05 PM
Posts: 30,427 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Typical with short runs building up condensation. It always rises to the top of the engine. Worse in areas that don't get washed by the oil. Common areas are oil fill, dipstick, and valve cover areas. Short runs and prolonged oil changes are the main cause. X 999 ... especially in colder weather LIKE in the U P of Meeeeeeechigan !
[Re: dOrk !]
#2739502
02/04/20 12:23 AM
02/04/20 12:23 AM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
4.7, especially when used for short trips, especially in cold weather. Replace the PCV. Clean the muck. Drive it. Mines at 220K and uses a little oil.
