Gunk in oil fill tube on 2001 Durango with the 4.7 engine #2739268
02/03/20 09:48 AM
02/03/20 09:48 AM
Missouri
Citation_SP Offline OP
Missouri
I have had this problem with my 2001 Durango since around 2007. Prior to 2007 the engine used no oil between oil changes however after 2007 the oil consumption went to 3 quarts between oil changes after the gunk appeared.
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: Citation_SP] #2739280
02/03/20 10:43 AM
02/03/20 10:43 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it's not using coolant, don't worry about the muck(there are tsb's on that), and if it's running good, I would put a new mfg's pcv valve in it. 3 qts is way too much use.
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: Citation_SP] #2739281
02/03/20 10:44 AM
02/03/20 10:44 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
How does the coolant look? Any bubbles in the radiator? work
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: bobby66] #2739283
02/03/20 10:47 AM
02/03/20 10:47 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 01 Durango with the 4.7 did the same thing. I just assumed it was condensation mixing with oil vapor around the cap. I didn't notice any coolant leaks or excessive oil consumption.
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: burdar] #2739442
02/03/20 09:28 PM
02/03/20 09:28 PM
Paducah, KY USA Earth
jcruse64 Offline
jcruse64  Offline
Same here with an '02 4.7 Durango.
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: jcruse64] #2739475
02/03/20 11:01 PM
02/03/20 11:01 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Typical with short runs building up condensation. It always rises to the top of the engine. Worse in areas that don't get washed by the oil. Common areas are oil fill, dipstick, and valve cover areas. Short runs and prolonged oil changes are the main cause.
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: NITROUSN] #2739476
02/03/20 11:05 PM
02/03/20 11:05 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
X 999 ... especially in colder weather LIKE in the U P of Meeeeeeechigan !
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: dOc !] #2739502
02/04/20 12:23 AM
02/04/20 12:23 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
4.7, especially when used for short trips, especially in cold weather. Replace the PCV. Clean the muck. Drive it. Mines at 220K and uses a little oil.
Re: Gunk in oil fill tube on 2001 Durango with the 4.7 engine [Re: buildanother] #2739558
02/04/20 09:45 AM
02/04/20 09:45 AM
Missouri
Missouri
Hi,
No coolant usage, just water running out of the PCV valve into the oil fill tube from condensation when the engine is turned off during cold weather only ( I live in the St. Louis, Mo area). Do you have the TSB number for this issue? By the way I replace the PCV valve with a Mopar part once a year.
Thanks,
Mike
