What oil to use in my 08 Hemi #273628
04/01/09 02:20 PM
04/01/09 02:20 PM
USA WI
Davews Offline OP
Davews  Offline OP
USA WI
Being a fanatic about changing my oil every 3000 miles, it's just about time to change the oil in my new 08 Ram Hemi. I'm thinking about going with Mobil 1 in my truck (never used synthetic before).I just wanted to make sure those rumors or myths about damaging seals was just that,not true. Any other thoughts would be appreciated? Dave
Re: What oil to use in my 08 Hemi [Re: Davews] #273629
04/01/09 02:27 PM
04/01/09 02:27 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
I've used Mobil 1 in my 06 Hemi Ram from day 1 and had no issues at all.
Oh, and here comes the obligatory post from CompSyn in 5...4...3...
Earning every penny of that moderator paycheck.
DBAP
Re: What oil to use in my 08 Hemi [Re: Davews] #273630
04/01/09 02:27 PM
04/01/09 02:27 PM
Louisville, KY.
Scottmon Offline
Scottmon  Offline
Louisville, KY.
Mobil 1 will be fine. Pick up a 5 quart jug in the weight of your choice at Walmart for $26.00.
It doesn't hurt seals, but synthetic will eat the sludge and varnish out of an engine and may cause seal to leak if the varnish was all that kept it from leaking.
My attitude is that if the synthetic cleans the motor out and a seal starts to leak because it was weak it needed to be replaced anyway.
Re: What oil to use in my 08 Hemi [Re: Scottmon] #273631
04/01/09 02:48 PM
04/01/09 02:48 PM
USA WI
Davews Offline OP
Davews  Offline OP
USA WI
One other question...How many miles between changes with Mobil 1 ?
Re: What oil to use in my 08 Hemi [Re: Davews] #273632
04/01/09 02:57 PM
04/01/09 02:57 PM
I go 7500, and it's still really clean at the change.
DBAP
Re: What oil to use in my 08 Hemi [Re: Davews] #273633
04/01/09 03:01 PM
04/01/09 03:01 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
All motor oils must be compatible with the various seal materials used in an engine. Oil must not cause seals to shrink, crack, degrade or dissolve.
Ideally, oil should cause seals to expand or "swell" slightly to ensure continued proper sealing.
Re: What oil to use in my 08 Hemi [Re: Scottmon] #273634
04/01/09 04:14 PM
04/01/09 04:14 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
Don't forget to pick up 2 single quarts with that also. Our 2008 HEMI Ram takes 7 quarts.
Also note that the oil filter thread size is different than previous years. The can and seal look just like a 5281090 but the thread is larger.
No longer taking $h!t from anyone!
Re: What oil to use in my 08 Hemi [Re: DUFFMAN] #273635
04/01/09 07:14 PM
04/01/09 07:14 PM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
The thread size of the filter went from standard size to metric size.
Re: What oil to use in my 08 Hemi [Re: Davews] #273636
04/02/09 01:31 PM
04/02/09 01:31 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
You need to use the weight recomended in the manual. I have heard reports that thicker oil causes erratic operation of the MDS system.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: What oil to use in my 08 Hemi [Re: dgc333] #273637
04/02/09 02:32 PM
04/02/09 02:32 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
As well as the change interval or it will give them an excuse to void the lifetime powertrain warranty.
Re: What oil to use in my 08 Hemi [Re: Davews] #273638
04/03/09 12:08 AM
04/03/09 12:08 AM
Use Amsoil, its the best out there. Beat Mobil 1 in wear tests plus if you use their high mile oil filter you only have to change your oil and filter every 10,000 miles. They say go 20,000 miles on the oil and filter but dear God don't do that! I run this in my granite blue metallic 2006 single cab Chevy 3500 4X4 dually with the 360HP Duramax diesel and the 6 speed Allison tranny and that thing purrs like a kitten. Amsoil is the best, all others fall short. Plus you save money on the longer oil change intervals. Take care, Clint H.
Re: What oil to use in my 08 Hemi #273639
04/03/09 10:26 AM
04/03/09 10:26 AM
Rochester HIlls, MI
Blue66Charger Offline
Rochester HIlls, MI
Longer oil change intervals? Don't do it! People will spend thousands on super heavy-duty performance mods on a street driven vehicle and cheap-out on oil changes. Just can't figure?!
Re: What oil to use in my 08 Hemi #273640
04/03/09 10:34 AM
04/03/09 10:34 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i like beer
Re: What oil to use in my 08 Hemi [Re: 05dakota] #273641
04/03/09 10:06 PM
04/03/09 10:06 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
which he cannot do while under warranty.
That is simply not true. No manufacturer can deny warranty claims based on (1) the type of motor oil used, and (2) the length of the Oil Change Interval.
Sure they can make recommendations on what oil type, grade, and oil change interval to go by, but not doing so does not automatically void the warranty.
Warranty claims are approved or denied based on failure analysis.
If any manufacturer or dealership tried to say otherwise, they would be violation of the law.
Don’t believe me?
Research the Federal Magnuson-Moss Act of 1975 starting with THIS LINK.
CompSyn
Re: What oil to use in my 08 Hemi [Re: Scottmon] #273642
04/03/09 10:18 PM
04/03/09 10:18 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Have you seen the latest news on Mobil 1 motor oil?
Check out THIS LINK
CompSyn
Re: What oil to use in my 08 Hemi [Re: Blue66Charger] #273643
04/03/09 10:28 PM
04/03/09 10:28 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Change the oil at the recomended intervals, or even more often. I change mine every 2000 miles.
AS for the "you can extend the interval" law, good luck with that.
Machines require maintenance. Not doing the proper maintenance is considered driver abuse, and voids warrantees. Just the same as performance mods do.
The car manufacturers have all figured out that if they deny every warrenty claim they can, it will save them millions of dollars. These days they need every penny. Don't give them the opportunity to save some money at your expense over something silly like an oil change.
Re: What oil to use in my 08 Hemi [Re: dave571] #273644
04/03/09 10:41 PM
04/03/09 10:41 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
“Conventional wisdom has held that the oil should be changed about every 3,000 miles. This notion has been ingrained into people's heads for decades, in part as a marketing ploy by oil companies. The 3,000-mile interval made sense when engines used single-grade nondetergent oils. But with the latest oils and car designs, it's no longer necessary to change oil that often under normal driving conditions.” –Steve Ritter, in Chemical & Engineering News, March 13, 2006
You've got one thing right -
The major oil companies are laughing all the way to the bank
CompSyn
Re: What oil to use in my 08 Hemi [Re: not_a_charger] #273645
04/03/09 11:13 PM
04/03/09 11:13 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I prefer compulsory
Well, He did say "Any other thoughts would be appreciated?"
CompSyn
