Re: What oil to use in my 08 Hemi
[Re: Davews]
#273629
04/01/09 02:27 PM
04/01/09 02:27 PM
Posts: 19,968 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I've used Mobil 1 in my 06 Hemi Ram from day 1 and had no issues at all.
Oh, and here comes the obligatory post from CompSyn in 5...4...3...
Earning every penny of that moderator paycheck.
DBAP
[Re: dgc333]
#273637
04/02/09 02:32 PM
04/02/09 02:32 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
You need to use the weight recomended in the manual. I have heard reports that thicker oil causes erratic operation of the MDS system.
As well as the change interval or it will give them an excuse to void the lifetime powertrain warranty.
[Re: Davews]
#273638
04/03/09 12:08 AM
04/03/09 12:08 AM
Use Amsoil, its the best out there. Beat Mobil 1 in wear tests plus if you use their high mile oil filter you only have to change your oil and filter every 10,000 miles. They say go 20,000 miles on the oil and filter but dear God don't do that! I run this in my granite blue metallic 2006 single cab Chevy 3500 4X4 dually with the 360HP Duramax diesel and the 6 speed Allison tranny and that thing purrs like a kitten. Amsoil is the best, all others fall short. Plus you save money on the longer oil change intervals. Take care, Clint H.
#273640
04/03/09 10:34 AM
04/03/09 10:34 AM
Posts: 17,861 albany ny
05dakota
albany ny
[Re: 05dakota]
#273641
04/03/09 10:06 PM
04/03/09 10:06 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
which he cannot do while under warranty.
That is simply not true. No manufacturer can deny warranty claims based on (1) the type of motor oil used, and (2) the length of the Oil Change Interval.
Sure they can make recommendations on what oil type, grade, and oil change interval to go by, but not doing so does not automatically void the warranty.
Warranty claims are approved or denied based on failure analysis.
If any manufacturer or dealership tried to say otherwise, they would be violation of the law. Don’t believe me?
Research the Federal Magnuson-Moss Act of 1975 starting with THIS LINK.
CompSyn
[Re: Scottmon]
#273642
04/03/09 10:18 PM
04/03/09 10:18 PM
CompSyn
Pacific NW USA
Mobil 1 will be fine. Pick up a 5 quart jug in the weight of your choice at Walmart for $26.00.
It doesn't hurt seals, but synthetic will eat the sludge and varnish out of an engine and may cause seal to leak if the varnish was all that kept it from leaking.
My attitude is that if the synthetic cleans the motor out and a seal starts to leak because it was weak it needed to be replaced anyway.
Have you seen the latest news on Mobil 1 motor oil?
Check out THIS LINK
CompSyn
[Re: Blue66Charger]
#273643
04/03/09 10:28 PM
04/03/09 10:28 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Longer oil change intervals? Don't do it! People will spend thousands on super heavy-duty performance mods on a street driven vehicle and cheap-out on oil changes. Just can't figure?!
Change the oil at the recomended intervals, or even more often. I change mine every 2000 miles.
AS for the "you can extend the interval" law, good luck with that.
Machines require maintenance. Not doing the proper maintenance is considered driver abuse, and voids warrantees. Just the same as performance mods do.
The car manufacturers have all figured out that if they deny every warrenty claim they can, it will save them millions of dollars. These days they need every penny. Don't give them the opportunity to save some money at your expense over something silly like an oil change.
[Re: dave571]
#273644
04/03/09 10:41 PM
04/03/09 10:41 PM
CompSyn
Pacific NW USA
“Conventional wisdom has held that the oil should be changed about every 3,000 miles. This notion has been ingrained into people's heads for decades, in part as a marketing ploy by oil companies. The 3,000-mile interval made sense when engines used single-grade nondetergent oils. But with the latest oils and car designs, it's no longer necessary to change oil that often under normal driving conditions.” –Steve Ritter, in Chemical & Engineering News, March 13, 2006
You've got one thing right -
The major oil companies are laughing all the way to the bank
CompSyn
[Re: not_a_charger]
#273645
04/03/09 11:13 PM
04/03/09 11:13 PM
CompSyn
Pacific NW USA
I prefer compulsory
Well, He did say "Any other thoughts would be appreciated?"
CompSyn
