Page 1 of 3 1 2 3
my turn what will it run #273562
04/01/09 01:44 PM
04/01/09 01:44 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I'm bored and I plan on firning the engine soon, and getting some track time by the end of the month. so here goes I'd like to see 12.30's
70 Charger (no heater box or headlight buckets) Stock Interior. column shift, 318 t-bars.
Standard bore 440, TRW 6-pack pistons (.020), ported 516 heads 74cc using Fel-Pro headgasket (approx 10.75:1) w/ 2.14/1.81 (flow 260/190), 528 solid cam, 1.5 roller rockers, Aluminum 6-pack set-up. (carbs will be adjusted well before running), MP distrib, MSD wires, coil, headers, 3" all the way to the bumper, 727 w/ performance build, 2600-2800 stall, 3,91's. I will be running slicks, probably an L60-15.
Coming soon!!!!
Re: my turn what will it run [Re: Mr.Yuck] #273563
04/01/09 02:00 PM
04/01/09 02:00 PM
13.20's...
Re: my turn what will it run #273564
04/01/09 02:06 PM
04/01/09 02:06 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
13.20's...
yeah if it was a 340 car.
Re: my turn what will it run #273565
04/01/09 02:09 PM
04/01/09 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
13.20's...
You're being optimistic , I was thinking it wouldn't barely break 15 sec ???
Re: my turn what will it run [Re: Mr.Yuck] #273566
04/01/09 02:10 PM
04/01/09 02:10 PM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
I ran a 12.16 in my car with a very simular combo. I had the 282 DC cam and stock heads. I had 10.7-1 compression. Mind you, the weather was perfect. I would normanl run in the 12.3-4 range though.
Re: my turn what will it run [Re: JohnRR] #273567
04/01/09 02:12 PM
04/01/09 02:12 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
13.20's...
Thanks John, I can always count on you.
Coming soon!!!!
Re: my turn what will it run [Re: Mr.Yuck] #273568
04/01/09 02:13 PM
04/01/09 02:13 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
you did not say the weight[3600#maybe]
12.50 i think your tires are a weak link.
Re: my turn what will it run [Re: blownzoom440] #273569
04/01/09 02:18 PM
04/01/09 02:18 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
a 28x10.5x15 slick is not enough? I'll probably use ET streets or a similar type.
Re: my turn what will it run [Re: Mr.Yuck] #273570
04/01/09 02:21 PM
04/01/09 02:21 PM
central new york
pettyblue440 Offline
central new york
how did you get .020 pistons into a std bore block?
Re: my turn what will it run [Re: Mr.Yuck] #273571
04/01/09 02:21 PM
04/01/09 02:21 PM
ELYRIA,OH
ELYRIA,OH
sorry all i saw was the L60/15.i figured you ment a pro trac street tire or something.
Re: my turn what will it run [Re: Mr.Yuck] #273572
04/01/09 02:22 PM
04/01/09 02:22 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... I'd like to see 12.30's...
I think you're about 1/2 second on the optimistic side. But I could be wrong...
Re: my turn what will it run [Re: pettyblue440] #273573
04/01/09 02:25 PM
04/01/09 02:25 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I didn't do the build. All I know is they are forged 6-pack pistons (with the reliefs) and they measure about .020 in the hole.
Re: my turn what will it run [Re: BradH] #273574
04/01/09 02:29 PM
04/01/09 02:29 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
nah I ran 12.90's in a 67 coronet (3900lbs w/ me) w/ a maybe 9:1 440, stock 906 heads, Summit 488 cam, rpm intake 750DP and headers. With a similar stall and 3.91's. This car is lighter, has more compression, better heads, better cam, better exhaust, and better carbs...should be better than a tenth faster. Buddy ran 11.80's on a stock 67 GTX w/ a similar set-up...his heads were a little better and he ran a 509 w/ 4.10's. Not that I expect to get close to 11's....but jeesh I hope it's better than 12.80's
Re: my turn what will it run [Re: Mr.Yuck] #273575
04/01/09 02:58 PM
04/01/09 02:58 PM
BradH Offline
BradH  Offline
I understand. Only one way to know for sure.
Re: my turn what will it run [Re: BradH] #273576
04/01/09 02:59 PM
04/01/09 02:59 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
"I understand. Only one way to know for sure."
You bet I'm gonna drive it like a rental as soon as I can.
Re: my turn what will it run [Re: Mr.Yuck] #273577
04/01/09 03:08 PM
04/01/09 03:08 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Jeff, I'm thinking your looking at high 12's low 13's there. I'll go with 13 flat.
DC
Re: my turn what will it run [Re: dc426] #273578
04/01/09 03:36 PM
04/01/09 03:36 PM
12.50 or faster if properly tuned,i,d guess low 13,s to start with and progressing to the 12.50 range after you figure out how to make it happy. Good luck
Re: my turn what will it run [Re: dc426] #273579
04/01/09 03:43 PM
04/01/09 03:43 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
DC
I agree. the cam you are using isn't that great. 509 in our experience will give you more but not as nice mannered. A little more gear would help too.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: my turn what will it run [Re: Mr.Yuck] #273580
04/01/09 03:47 PM
04/01/09 03:47 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
FWIW,
My old 440 was 10.5 to 1 with ported 452s. 509 Cam, m1 intake, 800 DP, 10 inch converter that flashed right at 4k, 4.30 gear, 3850 lbs. Ran a best of 12.46
Id think that charger shoud weigh really close to 4k if not a hair over.
IMO, you need way more converter.
Id say high 12's at best.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: my turn what will it run [Re: dc426] #273581
04/01/09 04:10 PM
04/01/09 04:10 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
DC
13 flat? come on...this car is lighter than my 67...and it has way more motor. was the 67 a fluke or something? I'l be really P/O'd if it doesn't run at least 12.50.
Page 1 of 3 1 2 3
