my turn what will it run
#273562
04/01/09 01:44 PM
04/01/09 01:44 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'm bored and I plan on firning the engine soon, and getting some track time by the end of the month. so here goes I'd like to see 12.30's 70 Charger (no heater box or headlight buckets) Stock Interior. column shift, 318 t-bars. Standard bore 440, TRW 6-pack pistons (.020), ported 516 heads 74cc using Fel-Pro headgasket (approx 10.75:1) w/ 2.14/1.81 (flow 260/190), 528 solid cam, 1.5 roller rockers, Aluminum 6-pack set-up. (carbs will be adjusted well before running), MP distrib, MSD wires, coil, headers, 3" all the way to the bumper, 727 w/ performance build, 2600-2800 stall, 3,91's. I will be running slicks, probably an L60-15.
Re: my turn what will it run
[Re: Mr.Yuck]
#273563
04/01/09 02:00 PM
04/01/09 02:00 PM
#273564
04/01/09 02:06 PM
04/01/09 02:06 PM
Mr.Yuck
Brookeville, Md
13.20's...
yeah if it was a 340 car.
[Re: JohnRR]
#273567
04/01/09 02:12 PM
04/01/09 02:12 PM
Mr.Yuck
Brookeville, Md
13.20's...
You're being optimistic , I was thinking it wouldn't barely break 15 sec ???
Thanks John, I can always count on you.
[Re: blownzoom440]
#273569
04/01/09 02:18 PM
04/01/09 02:18 PM
Mr.Yuck
Brookeville, Md
you did not say the weight[3600#maybe] 12.50 i think your tires are a weak link.
a 28x10.5x15 slick is not enough? I'll probably use ET streets or a similar type.
[Re: Mr.Yuck]
#273570
04/01/09 02:21 PM
04/01/09 02:21 PM
Posts: 6,743 central new york
pettyblue440
central new york
how did you get .020 pistons into a std bore block?
[Re: Mr.Yuck]
#273572
04/01/09 02:22 PM
04/01/09 02:22 PM
BradH
... I'd like to see 12.30's...
I think you're about 1/2 second on the optimistic side. But I could be wrong...
[Re: BradH]
#273574
04/01/09 02:29 PM
04/01/09 02:29 PM
Mr.Yuck
Brookeville, Md
nah I ran 12.90's in a 67 coronet (3900lbs w/ me) w/ a maybe 9:1 440, stock 906 heads, Summit 488 cam, rpm intake 750DP and headers. With a similar stall and 3.91's. This car is lighter, has more compression, better heads, better cam, better exhaust, and better carbs...should be better than a tenth faster. Buddy ran 11.80's on a stock 67 GTX w/ a similar set-up...his heads were a little better and he ran a 509 w/ 4.10's. Not that I expect to get close to 11's....but jeesh I hope it's better than 12.80's
[Re: Mr.Yuck]
#273575
04/01/09 02:58 PM
04/01/09 02:58 PM
BradH
I understand. Only one way to know for sure.
[Re: dc426]
#273578
04/01/09 03:36 PM
04/01/09 03:36 PM
12.50 or faster if properly tuned,i,d guess low 13,s to start with and progressing to the 12.50 range after you figure out how to make it happy. Good luck
[Re: Mr.Yuck]
#273580
04/01/09 03:47 PM
04/01/09 03:47 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
FWIW, My old 440 was 10.5 to 1 with ported 452s. 509 Cam, m1 intake, 800 DP, 10 inch converter that flashed right at 4k, 4.30 gear, 3850 lbs. Ran a best of 12.46 Id think that charger shoud weigh really close to 4k if not a hair over. IMO, you need way more converter. Id say high 12's at best.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: dc426]
#273581
04/01/09 04:10 PM
04/01/09 04:10 PM
Mr.Yuck
Brookeville, Md
Jeff, I'm thinking your looking at high 12's low 13's there. I'll go with 13 flat. DC
13 flat? come on...this car is lighter than my 67...and it has way more motor. was the 67 a fluke or something? I'l be really P/O'd if it doesn't run at least 12.50.
