Wrist pin lenght #2734371
01/19/20 09:00 AM
01/19/20 09:00 AM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello, I need your opinion on this.
Stock pin is 2.75" long. Want to run some boosted application and found some 2.65" pins that handles 300hp each.
So there Will be a 0.10" difference 0.05" each site. Do your think this room to spiro locks can created some problem or no problem here?
Br
1973 Brasilian Dart
E100, boosted 390"
Re: Wrist pin lenght [Re: dart_73_br] #2734378
01/19/20 09:47 AM
01/19/20 09:47 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would not be concerned with the difference in length as much as the difference in weight.
Re: Wrist pin lenght [Re: TRENDZ] #2734496
01/19/20 02:31 PM
01/19/20 02:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have always read and been told that the locks should fit to the pins fairly snug. Any free space can result in the pin beating the locks out of the groove. You can use a short pin, but the piston needs to be machined to match it.
I'm not the sharpest engine guy, but I pay attention. Will see if the sharp guys agree.
Re: Wrist pin lenght [Re: dart_73_br] #2734531
01/19/20 04:10 PM
01/19/20 04:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
How much thicker are the new pins and what material are they made from?
Blower motors need strong stiff wrist pins to keep them from bending and hurting the motor.
Re: Wrist pin lenght [Re: Cab_Burge] #2734783
01/20/20 09:33 AM
01/20/20 09:33 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
BENDING wrist pins ? Is that a common accordance in Bend, OREeGONE ?
Good to see ur not BENDING THE RULES on smilie limits per post ! ..
But zErO smilies?.... is ur keyboard mAlFuNcTiOnInG ? whistling xmaseek
Re: Wrist pin lenght [Re: dOoC] #2734787
01/20/20 09:43 AM
01/20/20 09:43 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You can absolutely bend wrist pins. Using “standard” pins does result in smile shaped wrist pins. I’ve had to cut out more than one set in two different engines.
Re: Wrist pin lenght [Re: dart_73_br] #2735010
01/20/20 05:50 PM
01/20/20 05:50 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Br
I would not use them in a piston that was not designed for them or at least modified.
Re: Wrist pin lenght [Re: Cab_Burge] #2737332
01/28/20 05:28 AM
01/28/20 05:28 AM
Sao Paulo, Brazil
Sao Paulo, Brazil
Hello,
new pins are H13 0.210" wall. Stock is 0.150". As this will ne a boosted application some friends suggested to upgrade piston pin.
http://blog.diamondracing.net/when-to-upgrade-wrist-pins
1973 Brasilian Dart
E100, boosted 390"
Re: Wrist pin lenght [Re: dart_73_br] #2741196
02/09/20 12:42 PM
02/09/20 12:42 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Br
DO NOT use a 2.650" long pin in a piston made for a 2.750" long pins, ever.
The question isn't if, but how many pistons you'll throw on the track if you assemble your engine that way.
