Wrist pin lenght
#2734371
01/19/20 09:00 AM
01/19/20 09:00 AM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Hello, I need your opinion on this.
Stock pin is 2.75" long. Want to run some boosted application and found some 2.65" pins that handles 300hp each. So there Will be a 0.10" difference 0.05" each site. Do your think this room to spiro locks can created some problem or no problem here?
Br
1973 Brasilian Dart E100, boosted 390"
Re: Wrist pin lenght
[Re: dart_73_br]
#2734378
01/19/20 09:47 AM
01/19/20 09:47 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would not be concerned with the difference in length as much as the difference in weight.
[Re: TRENDZ]
#2734496
01/19/20 02:31 PM
01/19/20 02:31 PM
Posts: 11,550 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have always read and been told that the locks should fit to the pins fairly snug. Any free space can result in the pin beating the locks out of the groove. You can use a short pin, but the piston needs to be machined to match it.
I'm not the sharpest engine guy, but I pay attention. Will see if the sharp guys agree.
[Re: dart_73_br]
#2734531
01/19/20 04:10 PM
01/19/20 04:10 PM
Posts: 43,141 Bend,OR USA
Cab_Burge
How much thicker are the new pins and what material are they made from? Blower motors need strong stiff wrist pins to keep them from bending and hurting the motor.
[Re: Cab_Burge]
#2734783
01/20/20 09:33 AM
01/20/20 09:33 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
How much thicker are the new pins and what material are they made from? Blower motors need strong stiff wrist pins to keep them from bending and hurting the motor. BENDING wrist pins ? Is that a common accordance in Bend, OREeGONE ? Good to see ur not BENDING THE RULES on smilie limits per post ! .. But zErO smilies?.... is ur keyboard mAlFuNcTiOnInG ?
[Re: dOrk !]
#2734787
01/20/20 09:43 AM
01/20/20 09:43 AM
TRENDZ
Milwaukee WI
You can absolutely bend wrist pins. Using “standard” pins does result in smile shaped wrist pins. I’ve had to cut out more than one set in two different engines.
[Re: dart_73_br]
#2735010
01/20/20 05:50 PM
01/20/20 05:50 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Br I would not use them in a piston that was not designed for them or at least modified.
[Re: dart_73_br]
#2741196
02/09/20 12:42 PM
02/09/20 12:42 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
Br DO NOT use a 2.650" long pin in a piston made for a 2.750" long pins, ever. The question isn't if, but how many pistons you'll throw on the track if you assemble your engine that way.
