Help with trailer purchase please #273454
04/01/09 10:32 AM
04/01/09 10:32 AM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Would this be a good trailer? Its a Pace 28 ft.
RT8528TA3H
>> 12 ELECTRIC BRAKES 1 N/A
>> 15 3/8 PLYWOOD SIDEWALLS 1 N/A
>> 2 ST225 75R15 LRD RADIAL TIRES 1 N/A
>> 21 8 I BEAM FRAME 1 N/A
>> 22 TRIPLE TUBE TONGUE 1 N/A
>> 23 2 5/16 COUPLER W/JACK (<10K) 1 N/A
>> 31 ITS AXLES/TANDEM/5000# 1 N/A
>> 35 030 SMOOTH EXTERIOR METAL 1 N/A
>> 37 BEAVERTAIL 1 N/A
>> 47 STANDARD HITCH 1 N/A
>> 6 3/4 PLYWOOD FLOOR 1 N/A
>> 63 12 VT BREAKAWAY SWITCH 1 N/A
>> 64 WALL POSTS @ 16 O/C 1 N/A
>> 65 48 SX SOLID CORE SD DR 3' BACK 1 N/A
>> 66 SX REAR RAMP DOOR W/SPG ASSIST 1 N/A
>> 71 GALVANIZED ROOF 1 N/A
>> 76 CROSSMEMBERS @ 16 O/C 1 N/A
>> 85 CAST ALUMINUM REAR CORNERS 1 N/A
>> 95 RALLYE TRIM W/ CONSP. TAPE 1 N/A
>> 99 ALUMINUM FENDERETTES 1 N/A
>> 997 COLORED WRAPPED REAR END 1 N/A
>> 1001WHN 030 SMOOTH METAL WHITE/LTF 28 N/A
>> 13069 SAND FOOT ON A JACK 1 $4.00
>> 16428 COLRD FASTNRS WHITE / LTF 28 $56.00
>> 20054C 54 SIDE DOOR W/FLUSHLOCK 1 $265.00
>> R1027 RALLYE GS PKG 1 $449.00
>> 5002 POLISHED FRONT & REAR CASTINGS 1 N/A
>> R615 STAINLESS STEEL FRONT CORNERS 1 N/A
>> 99008 STAINLESS STEEL FRONT INSERT 1 N/A
>> 60014 SILVER MODS ILO WHITE MODS 1 N/A
>> 16103 ATP FRONT STONEGUARD 8.5'W 1 N/A
>> 12172I 5000# D-RING RECESS FLOOR/INST 4 N/A
>> 16033 NON-POWER ROOF VENT W/LID 2 N/A
>> 40012 SX 12 V DOME LIGHT 2 N/A
>> 40013 12V WALL SWITCH 1 N/A
>> 60030 STAINLESS STL CENTER CAPS 4 N/A
>> 16094 GS DOMED DECAL 2 N/A
>> R1030 FINISHED INTERIOR PACKAGE/LTF 28 $280.00
>> 90110F WHITE VINYL CEILING/LTF 28 N/A
71 Demon
Re: Help with trailer purchase please [Re: hemifw] #273455
04/01/09 10:38 AM
04/01/09 10:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like a nice trailer... the only thing I would
do is go with the bigger axles and tires, if you add
up the trailer weight and the stuff you put in it you
will see that you will be real close if not over the
rated weight
Re: Help with trailer purchase please [Re: MR_P_BODY] #273456
04/01/09 10:56 AM
04/01/09 10:56 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If your going to be towing W/ a MH I would opt for the extended tounge.
Re: Help with trailer purchase please [Re: hemifw] #273457
04/01/09 11:26 AM
04/01/09 11:26 AM
Lehigh Acres, Florida
rickstershemi Offline
JMO but I would give Mike Scott @ Right Trailers 863-667-4448 a call up in Lakeland if you haven't allready, he'll treat you right, mention my name (Rick Blake)
www.righttrailers.com
Mike's a great guy and Right Trailers sponsors a lot of sportsman racers as well as the Bracket Series at Bradenton....
Re: Help with trailer purchase please [Re: MR_P_BODY] #273458
04/01/09 11:52 AM
04/01/09 11:52 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
rated weight
I would NEVER run 15" tires on a enclosed trailer like that. Definity upgrade the axles and tires, FOR SURE./
Re: Help with trailer purchase please [Re: hemifw] #273459
04/01/09 09:28 PM
04/01/09 09:28 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Specs look just like my 04 Pace Shadow 28 ft.
I have 5k axles and still have the original tires but they are starting to crack.
I've towed it to hell and back behind the dually with the B body ,golf cart and all the other stuff, no problems at all.
Re: Help with trailer purchase please [Re: WILD BILL] #273460
04/01/09 10:12 PM
04/01/09 10:12 PM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
I don't tow with a motor home but I am real glad I got the extended tongue on my 24ft Classic RTX. I am not sure I could turn it sharp enough to get it backed in to the back yard without it.
Re: Help with trailer purchase please [Re: 340Cuda] #273461
04/01/09 10:19 PM
04/01/09 10:19 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I bought a 30 foot Pace ,
I opted for 2 6200 lbs axles , I also got the ext tongue, glad I did
Mine has show, bathroom,etc ..
lics as a RV so no trouble with Johnny Law
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Help with trailer purchase please [Re: Challenger 1] #273462
04/01/09 10:40 PM
04/01/09 10:40 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
rated weight
DO NOT get the 15"s on that size trailer. Been there, done that. I wasted almost $2000 on replacing blown tires before I finally upgraded to 16" load range E tires.
Lots of others I know have had the same experience. The next trailer I get will have wet hubs, too. You should check into that, they will save you time and $ in the long run.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Help with trailer purchase please [Re: Hemi_Joel] #273463
04/02/09 09:06 AM
04/02/09 09:06 AM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Thanks for the advice on the axles, I guess I will have to order a trailer then. This trailer I was looking at is farily basic, do I need the cabinets and gen compartment or is that something I should do on my own?
71 Demon
Re: Help with trailer purchase please [Re: hemifw] #273464
04/02/09 09:09 AM
04/02/09 09:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want a gen door, order that. If you dont mind
having wood cabinets you can go to Lowes or Home Depot
and put them in but if you want the alum cabinets, order
them also. Basically its your choice
Re: Help with trailer purchase please [Re: MR_P_BODY] #273465
04/02/09 11:42 AM
04/02/09 11:42 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
If your going to order one,,,you might want to consider a few things.
-wall and ceiling covering on mine...
-linolieum (sp) on the floor,,,with 4 D rings
-diamond plate the rear tail gate,,,and run some strips up into the trailer so the tires dont rip up the floor
-get cabinets,,,i had them installed,,,, i got the overhead,,,and the under cabinets,,,with a workbench,,,
-consider a winch,,,unless you get a escape door,,,where you can drive in and out...i like the winch.
-light package,,,so you can see inside at night,
-i wish i would have got the generator door
Re: Help with trailer purchase please [Re: 69CHARGERMD] #273466
04/02/09 12:07 PM
04/02/09 12:07 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
nice pics chargermd.i am not sure how the lanolium will holdup to the weight and leaks that may be induced.i lucked out finding some aluminum on sale and did the whole floor insted of just a tire path.
Re: Help with trailer purchase please [Re: 69CHARGERMD] #273467
04/02/09 12:19 PM
04/02/09 12:19 PM
ELYRIA,OH
ELYRIA,OH
i just saw that you are pulling that with a dakota.so am i![ext cab]i have not loaded the car yet so maybe you could PM me some loading tips and how it handles.[please]
Re: Help with trailer purchase please [Re: blownzoom440] #273468
04/02/09 12:31 PM
04/02/09 12:31 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have vynle tile in mine and it's not holding up that well. If I had to do it over again I think I would do the rubber coin flooring. I think a winch is a must have. Never know when the car is going to break and not be able to be driven up in the trailer.
DIamond plate under the tires has helped minimize the damge to the floor though.
Also, if you order one, a 48" side door W/ an RV style latch is nice.
Re: Help with trailer purchase please [Re: hemifw] #273469
04/02/09 03:12 PM
04/02/09 03:12 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The options you can purchase on a enclosed are endless, I think the gen "L" is a total waste of space myself ..
If you look into the nice inverters both Honda and Yamaha make depending on what you have to run in trailer you can have a nice, small, quiet genset
In the same area more or less I have a shower and toliet in my trailer ..
Cabinets are nice on the top side but, the lower ones again take allot of space up (I figured that in on mine) but, they do have a use ,like for my winch to be hid, built shelves inside them so they just don't end up being piled full of junk
I got rubber coin floor in my trailer , the best way to decide I think is go to a close divisional or national event and look thru the sportsman pits, most of those fellas will give you good tips on what to or not to buy
I'll post a few more of my trailer ..
And, I say one more thing In my opinion , you should never, ever consider buying a enclosed if you do not have the proper unit to tow it
If you live close to the track, yes ..Maybe you COULD get by with a half ton or something but, it is not exactly legal and its surely not safe
Not to mention, they just do not have the power , suspension ,etc to do a good job
Re: Help with trailer purchase please [Re: bigdad] #273470
04/02/09 03:13 PM
04/02/09 03:13 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
electric tongue jack good option ..price is fair
Re: Help with trailer purchase please [Re: bigdad] #273471
04/02/09 03:14 PM
04/02/09 03:14 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
window in rest area
Re: Help with trailer purchase please [Re: bigdad] #273472
04/02/09 03:15 PM
04/02/09 03:15 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
cabinets
Re: Help with trailer purchase please [Re: bigdad] #273473
04/02/09 03:16 PM
04/02/09 03:16 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
shelf built inside cabinet
