Help with trailer purchase please
#273454
04/01/09 10:32 AM
04/01/09 10:32 AM
Posts: 82 florida
hemifw
florida
Would this be a good trailer? Its a Pace 28 ft. RT8528TA3H >> 12 ELECTRIC BRAKES 1 N/A >> 15 3/8 PLYWOOD SIDEWALLS 1 N/A >> 2 ST225 75R15 LRD RADIAL TIRES 1 N/A >> 21 8 I BEAM FRAME 1 N/A >> 22 TRIPLE TUBE TONGUE 1 N/A >> 23 2 5/16 COUPLER W/JACK (<10K) 1 N/A >> 31 ITS AXLES/TANDEM/5000# 1 N/A >> 35 030 SMOOTH EXTERIOR METAL 1 N/A >> 37 BEAVERTAIL 1 N/A >> 47 STANDARD HITCH 1 N/A >> 6 3/4 PLYWOOD FLOOR 1 N/A >> 63 12 VT BREAKAWAY SWITCH 1 N/A >> 64 WALL POSTS @ 16 O/C 1 N/A >> 65 48 SX SOLID CORE SD DR 3' BACK 1 N/A >> 66 SX REAR RAMP DOOR W/SPG ASSIST 1 N/A >> 71 GALVANIZED ROOF 1 N/A >> 76 CROSSMEMBERS @ 16 O/C 1 N/A >> 85 CAST ALUMINUM REAR CORNERS 1 N/A >> 95 RALLYE TRIM W/ CONSP. TAPE 1 N/A >> 99 ALUMINUM FENDERETTES 1 N/A >> 997 COLORED WRAPPED REAR END 1 N/A >> 1001WHN 030 SMOOTH METAL WHITE/LTF 28 N/A >> 13069 SAND FOOT ON A JACK 1 $4.00 >> 16428 COLRD FASTNRS WHITE / LTF 28 $56.00 >> 20054C 54 SIDE DOOR W/FLUSHLOCK 1 $265.00 >> R1027 RALLYE GS PKG 1 $449.00 >> 5002 POLISHED FRONT & REAR CASTINGS 1 N/A >> R615 STAINLESS STEEL FRONT CORNERS 1 N/A >> 99008 STAINLESS STEEL FRONT INSERT 1 N/A >> 60014 SILVER MODS ILO WHITE MODS 1 N/A >> 16103 ATP FRONT STONEGUARD 8.5'W 1 N/A >> 12172I 5000# D-RING RECESS FLOOR/INST 4 N/A >> 16033 NON-POWER ROOF VENT W/LID 2 N/A >> 40012 SX 12 V DOME LIGHT 2 N/A >> 40013 12V WALL SWITCH 1 N/A >> 60030 STAINLESS STL CENTER CAPS 4 N/A >> 16094 GS DOMED DECAL 2 N/A >> R1030 FINISHED INTERIOR PACKAGE/LTF 28 $280.00 >> 90110F WHITE VINYL CEILING/LTF 28 N/A >> >> > >
71 Demon
Re: Help with trailer purchase please
[Re: hemifw]
#273455
04/01/09 10:38 AM
04/01/09 10:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks like a nice trailer... the only thing I would do is go with the bigger axles and tires, if you add up the trailer weight and the stuff you put in it you will see that you will be real close if not over the rated weight ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#273456
04/01/09 10:56 AM
04/01/09 10:56 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If your going to be towing W/ a MH I would opt for the extended tounge.
[Re: MR_P_BODY]
#273458
04/01/09 11:52 AM
04/01/09 11:52 AM
Challenger 1
Cincinnati, Ohio
![](/ubbthreads/images/graemlins/iagree.gif)
I would NEVER run 15" tires on a enclosed trailer like that. Definity upgrade the axles and tires, FOR SURE./
[Re: WILD BILL]
#273460
04/01/09 10:12 PM
04/01/09 10:12 PM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I don't tow with a motor home but I am real glad I got the extended tongue on my 24ft Classic RTX. I am not sure I could turn it sharp enough to get it backed in to the back yard without it.
[Re: 340Cuda]
#273461
04/01/09 10:19 PM
04/01/09 10:19 PM
Posts: 34,962 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I bought a 30 foot Pace , I opted for 2 6200 lbs axles , I also got the ext tongue, glad I did
Mine has show, bathroom,etc .. lics as a RV so no trouble with Johnny Law
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Challenger 1]
#273462
04/01/09 10:40 PM
04/01/09 10:40 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
DO NOT get the 15"s on that size trailer. Been there, done that. I wasted almost $2000 on replacing blown tires before I finally upgraded to 16" load range E tires. Lots of others I know have had the same experience. The next trailer I get will have wet hubs, too. You should check into that, they will save you time and $ in the long run.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#273463
04/02/09 09:06 AM
04/02/09 09:06 AM
Posts: 82 florida
hemifw
florida
Thanks for the advice on the axles, I guess I will have to order a trailer then. This trailer I was looking at is farily basic, do I need the cabinets and gen compartment or is that something I should do on my own?
71 Demon
[Re: MR_P_BODY]
#273465
04/02/09 11:42 AM
04/02/09 11:42 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
If your going to order one,,,you might want to consider a few things. -wall and ceiling covering on mine... -linolieum (sp) on the floor,,,with 4 D rings -diamond plate the rear tail gate,,,and run some strips up into the trailer so the tires dont rip up the floor -get cabinets,,,i had them installed,,,, i got the overhead,,,and the under cabinets,,,with a workbench,,, -consider a winch,,,unless you get a escape door,,,where you can drive in and out...i like the winch. -light package,,,so you can see inside at night, -i wish i would have got the generator door ![](/ubbthreads/images/graemlins/Twocents.gif) ![](http://i212.photobucket.com/albums/cc79/69CHARGERMD/P5250006.jpg) ![](http://i212.photobucket.com/albums/cc79/69CHARGERMD/P5250004.jpg) ![](http://i212.photobucket.com/albums/cc79/69CHARGERMD/P5250001.jpg)
[Re: 69CHARGERMD]
#273466
04/02/09 12:07 PM
04/02/09 12:07 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
nice pics chargermd.i am not sure how the lanolium will holdup to the weight and leaks that may be induced.i lucked out finding some aluminum on sale and did the whole floor insted of just a tire path.
[Re: blownzoom440]
#273468
04/02/09 12:31 PM
04/02/09 12:31 PM
WILD BILL
BROOK PARK, OH
I have vynle tile in mine and it's not holding up that well. If I had to do it over again I think I would do the rubber coin flooring. I think a winch is a must have. Never know when the car is going to break and not be able to be driven up in the trailer. ![](/ubbthreads/images/graemlins/Twocents.gif)
DIamond plate under the tires has helped minimize the damge to the floor though.
Also, if you order one, a 48" side door W/ an RV style latch is nice.
[Re: hemifw]
#273469
04/02/09 03:12 PM
04/02/09 03:12 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
The options you can purchase on a enclosed are endless, I think the gen "L" is a total waste of space myself ..
If you look into the nice inverters both Honda and Yamaha make depending on what you have to run in trailer you can have a nice, small, quiet genset
In the same area more or less I have a shower and toliet in my trailer ..
Cabinets are nice on the top side but, the lower ones again take allot of space up (I figured that in on mine) but, they do have a use ,like for my winch to be hid, built shelves inside them so they just don't end up being piled full of junk
I got rubber coin floor in my trailer , the best way to decide I think is go to a close divisional or national event and look thru the sportsman pits, most of those fellas will give you good tips on what to or not to buy
I'll post a few more of my trailer ..
And, I say one more thing In my opinion , you should never, ever consider buying a enclosed if you do not have the proper unit to tow it
If you live close to the track, yes ..Maybe you COULD get by with a half ton or something but, it is not exactly legal and its surely not safe
Not to mention, they just do not have the power , suspension ,etc to do a good job
[Re: bigdad]
#273470
04/02/09 03:13 PM
04/02/09 03:13 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
electric tongue jack good option ..price is fair
[Re: bigdad]
#273473
04/02/09 03:16 PM
04/02/09 03:16 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
shelf built inside cabinet
