Door panel restoration #273092
03/31/09 10:19 PM
03/31/09 10:19 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
My door panels are black but are faded at the top to the point where there pretty much gray. Is there a dye that I can rub in to restore these. Im afraid that if I use the paint they make for the interior panels, it will fill in the grain of the panels. Any ideas?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Door panel restoration [Re: 73cuda340] #273093
04/01/09 01:02 PM
04/01/09 01:02 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Any dye, which is really paint, will not soak into the plastic.
Seeing as you have black panels, which are the easiest to get, I'd just say get better panels at a swap meet or something. Repros suck. Stick with an original set.
Re: Door panel restoration [Re: RP's R/T's] #273094
04/01/09 04:20 PM
04/01/09 04:20 PM
Colorado
CuriousYella70 Offline
Colorado
Why won't it stick to the door panels? I've heard of a lot of people successfully re-dying their entire interiors, plastic pieces and all?
Re: Door panel restoration [Re: CuriousYella70] #273095
04/01/09 04:24 PM
04/01/09 04:24 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
I redid my interior panels with the ppg specialty paint.... I am really pleased with the result. The paint is a jet black color(low gloss). It didn't fill in the grain at all and has a nice almost satin look to it.... I will get you the part number when I get home tonight. This stuff is premixed and all you do is shoot it after a little prep.
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Door panel restoration [Re: MoparJunkie] #273096
04/01/09 04:49 PM
04/01/09 04:49 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I haven't personally dyed or sprayed any, but from everything I've heard, it looks great if done properly. Everyone I know agrees that the re-pops are JUNK...Stay away from them. I've always advised people needing E-body door panels to get a good used black set and use them black or re-color them. In your case you have a black set with good grain, albeit faded. Buy the SEM dye and re-use what you have. Save your money by not buying another set of panels...
Re: Door panel restoration [Re: 318 Stroker] #273097
04/01/09 04:52 PM
04/01/09 04:52 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What are you to do if you have a few scratches in the finish where the "texture" has scraped off. If you spray the panels you will still see those areas.
Re: Door panel restoration [Re: burdar] #273098
04/01/09 05:05 PM
04/01/09 05:05 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Once the plastic has degraded from UV and becomes crumbly chalky dust there's no fix other than re-skinning the entire panel (which is expensive).
If the plastic is still fresh and not sun rotted you can freshen up a dull looking set and mask minor flaws and scratches etc. with a coat of dye (paint) but you won't be hiding much else.
Re: Door panel restoration [Re: ScottSmith_Harms] #273099
04/01/09 05:17 PM
04/01/09 05:17 PM
Colorado
Colorado
Check out the Cuda thread in the projects/survivors section -- If i'm not mistaken, he restored his Cuda door panels and they looked/sounded a lot worse then yours
Re: Door panel restoration [Re: CuriousYella70] #273100
04/01/09 06:22 PM
04/01/09 06:22 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Let me elaborate.
Current paints do attach themselves to the plastic door panels relatively well. However, it will not last forever and if you hit it right the paint will come off. Whether this happens right away or in a few years...it will happen. The plastics that are on new car bumpers are formulated to accept paint adhesion. 1970's door panels were not formulated for this. They are polyethelene, which does not allow for great paint adhesion.
However, if you have a color interior, it's probably your only/best option.
My point was, if you have black panels, just buy another set. Black is the easiest to get. I personally wouldn't go through the hassle to paint black panels and then worry about matching gloss with the rest of the interior and also worry about paint adhesion. However, maybe the budget doesn't allow for this.
Also, if painted well, you won't fill in the grain. However, I have seen some panels where they were painted too heavily and it did fill in the grain.
Re: Door panel restoration [Re: RP's R/T's] #273101
04/01/09 07:12 PM
04/01/09 07:12 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
paint will lift sooner or later.the top area where it is worn smooth will lift faster...unless u scuff it up....
Re: Door panel restoration [Re: ScottSmith_Harms] #273102
04/02/09 12:04 AM
04/02/09 12:04 AM
clarks summit pa
clarks summit pa
There not at the point of the dust yet. The plastic is still in very good shape; it's just that it is turning gray on the tops. I'll try to give them a good cleaning and see how they come out.
Re: Door panel restoration [Re: RP's R/T's] #273103
04/02/09 12:14 AM
04/02/09 12:14 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
They are made out of polypropylene, the same stuff they make water resistant ropes out of. It accepts paint/dye even worse than polyethylene does.
Black is not only the easiest to get, they survived far better than any other color, including white. I had no choice as there does not seem to be any surviving B5 blue panels out there without horrible chalking. Yeah, the black may show through one day but even if it does, it is a far cry from the greasy, chalky, scratched blue ones that survived.
Re: Door panel restoration [Re: denfireguy] #273104
04/02/09 12:06 PM
04/02/09 12:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here is a thread in the "member projects" section. This looks like it may be a good option for people with chalky door panels. His panels turned out looking pretty good.
https://board.moparts.org/ubbthreads/show...e=0#Post4916353
