Door panel restoration
#273092
03/31/09 10:19 PM
03/31/09 10:19 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
My door panels are black but are faded at the top to the point where there pretty much gray. Is there a dye that I can rub in to restore these. Im afraid that if I use the paint they make for the interior panels, it will fill in the grain of the panels. Any ideas?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Door panel restoration
[Re: CuriousYella70]
#273100
04/01/09 06:22 PM
04/01/09 06:22 PM
Posts: 763 SE Wisconsin, USA
RP's R/T's
SE Wisconsin, USA
Let me elaborate. Current paints do attach themselves to the plastic door panels relatively well. However, it will not last forever and if you hit it right the paint will come off. Whether this happens right away or in a few years...it will happen. The plastics that are on new car bumpers are formulated to accept paint adhesion. 1970's door panels were not formulated for this. They are polyethelene, which does not allow for great paint adhesion. However, if you have a color interior, it's probably your only/best option. My point was, if you have black panels, just buy another set. Black is the easiest to get. I personally wouldn't go through the hassle to paint black panels and then worry about matching gloss with the rest of the interior and also worry about paint adhesion. However, maybe the budget doesn't allow for this. Also, if painted well, you won't fill in the grain. However, I have seen some panels where they were painted too heavily and it did fill in the grain.
[Re: RP's R/T's]
#273103
04/02/09 12:14 AM
04/02/09 12:14 AM
Posts: 1,822 Colorado
denfireguy
Colorado
They are made out of polypropylene, the same stuff they make water resistant ropes out of. It accepts paint/dye even worse than polyethylene does.
Black is not only the easiest to get, they survived far better than any other color, including white. I had no choice as there does not seem to be any surviving B5 blue panels out there without horrible chalking. Yeah, the black may show through one day but even if it does, it is a far cry from the greasy, chalky, scratched blue ones that survived.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
