Question for Amsoil racing oil users #272349
03/31/09 10:34 AM
03/31/09 10:34 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
The closest auto parts store to my house stocks most of the Amsoil line and I'm considering using their Series 2000 in my Challenger. Do you folks who run Amsoil in your race or street/strip cars use an oil analysis program to determine your change intervals? Since the stuff has a high TBN level (12), it "should" be able to last quite a while and not need to be changed as frequently as oils w/ lower TBN ratings. And, at $10 a quart, I'd hope it wouldn't need to be drained as frequently, either. Any other comments about the product are appreciated, too.
Re: Question for Amsoil racing oil users [Re: BradH] #272350
03/31/09 02:54 PM
03/31/09 02:54 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Good ole Amsoil .... ...and their marketing BS ...
WHERE do they suggest that the combustion by-products GO ... that are in their oil vs staying in the other brands ?
10$ a quart ? .... that is due to their multi-level-sales and marketing program that has so many hands-in-the-pie.
Re: Question for Amsoil racing oil users [Re: dOoC] #272351
03/31/09 04:34 PM
03/31/09 04:34 PM
BradH Offline OP
BradH  Offline OP
So far...
Replies = 1
Value Added = 0
Re: Question for Amsoil racing oil users [Re: BradH] #272352
03/31/09 05:52 PM
03/31/09 05:52 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Hey Brad I hope you feel this is on topic because I was going to start an oil thread asking about synthetic oils. I have been reading about different synthetic oils with different base stocks Amsoil is supposed to be POA base stock oil with ester base stock being the best and POA being second best but much cheaper. My transmission builder uses amsoil in his 1500 hp nitrous engine on alcohol and is very happy with it. Maybe some of the chemists will chime in.
Re: Question for Amsoil racing oil users [Re: BradH] #272353
03/31/09 07:32 PM
03/31/09 07:32 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I tried it, runs suggested it was probably .02 quicker in the quarter. That was going from 20W-50 Valvoline to Amsoil 10W-30 back in the mid 90's. It is also a good test on how well your rear main is sealed up. Bearings looked pretty much the same. I believe synthetics are better oils but IMO not worth the hi cost. I went back to the 20W-50 Valvoline and am still running it. I never used anything other than my judgement to determine change intervals. I try to change every 50 - 60 passes. This is my
Re: Question for Amsoil racing oil users [Re: BradH] #272354
03/31/09 07:39 PM
03/31/09 07:39 PM
Florida STAYcation
Florida STAYcation
So far...
Replies = 1
Value Added = 0
Oh really now ? ..... and my responses were directly ON TOPIC....to exactly what you said.
PLUS ... Wasn't it YOU that stated this ?
""""""" Any other comments about the product are appreciated, too. """"""
Re: Question for Amsoil racing oil users [Re: BradH] #272355
03/31/09 09:06 PM
03/31/09 09:06 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
You should contact member "Locomotion",Myron Piatek.He swears by Amsoil and has been using it for many years.There was also a thread about synthetics and a post was made about the price being cheaper that $10 a quart.
Nautilus Racing-
Re: Question for Amsoil racing oil users [Re: Chris2581] #272356
03/31/09 09:10 PM
03/31/09 09:10 PM
south louisiana
lowell66dart Offline
south louisiana
I've been using Amsoil for 20 + years in everything I own. I can also tell you how to get it for less than $10, just pm me. There are lots of great oils out there.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Question for Amsoil racing oil users [Re: dOoC] #272357
04/01/09 10:52 AM
04/01/09 10:52 AM
BradH Offline OP
BradH  Offline OP
So far...
Replies = 1
Value Added = 0
Next time I'll be sure to specify VALUE-ADDING comments, rather than ANY.
Re: Question for Amsoil racing oil users [Re: BradH] #272358
04/01/09 12:23 PM
04/01/09 12:23 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
What Amsoil says is that the oil is good for 25000 miles. You change to their oil and filter, and when you reach 12500 miles you replace the filter and add a quart of oil, then drive another 12500 and your ready for a complete oil change. If you are using the by-pass filter along with a full-flow filter and have a oil sample checked in the lab you still change the filters and add oil put you dont change the oil untill the sample does not pass.
Re: Question for Amsoil racing oil users [Re: hemi471] #272359
04/01/09 01:23 PM
04/01/09 01:23 PM
BradH Offline OP
BradH  Offline OP
What Amsoil says is that the oil is good for 25000 miles...
That's for passenger cars only. For race applications, they tell you something along the lines of "follow your engine builder's recommendations" or to monitor the oil w/ a scheduled analysis program.
Re: Question for Amsoil racing oil users [Re: BradH] #272360
04/01/09 02:55 PM
04/01/09 02:55 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I use Amsoil also and have had the oil analysis done last year. Right after I sent in the oil sample I found out I had a thrust bearing issue. So I was expecting bad news from the sample. I got an e-mail and a phone call from the lab about the results On the report was a note that the use of race fuel will raise the level of lead in the sample. Many large fleets I have inspected at have oil analysis done on all vehicles as part of there maintenance. It is a good look into what is going on inside the engine. Many issues have been found before they knew a problem existed with a piece of equipment.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Question for Amsoil racing oil users [Re: BradH] #272361
04/01/09 04:38 PM
04/01/09 04:38 PM
organ
maximum entropy Offline
organ
Value Added = 0
Re: Question for Amsoil racing oil users [Re: maximum entropy] #272362
04/01/09 11:36 PM
04/01/09 11:36 PM
Florida STAYcation
Florida STAYcation
Value Added = 0
Amsoil drones don't want to hear the TRUTH !
Re: Question for Amsoil racing oil users [Re: dOoC] #272363
04/02/09 02:06 AM
04/02/09 02:06 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
There are those who are afraid of it. And there are those who knock it. Then there are those who actually do it.
Extended Oil Drain technology has existed since 1972.
The links below show how Used Oil Analysis (UOA) can support a lube manufactures claims. Independent person... Independent lab...
0W-30, 20,000-mile UOA report, 2004 Crown Victoria - link
0W-20, 28,000-mile UOA report, 2003 Sable - link
0W-30, 30,726-mile UOA report, 2003 Honda S2000 - link
Get the Series 2000 HDD, do a UOA when it comes time and don’t look back.
CompSyn
Re: Question for Amsoil racing oil users [Re: mac56] #272364
04/02/09 02:16 AM
04/02/09 02:16 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Amsoil has many formulations that are PAO/Ester based - hence the high price tag. They also have Group III formulations which are more in line with the cost of Valvoline SynPower, Pennzoil Platinum and Mobil 1 varieties.
It all depends on how exotic one wants to go.
CompSyn
Re: Question for Amsoil racing oil users [Re: Chris2581] #272365
04/02/09 02:30 AM
04/02/09 02:30 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Amsoil Preferred Customer Discount - link
There’s no need for anyone to have to pay retail...
CompSyn
Re: Question for Amsoil racing oil users [Re: CompSyn] #272366
04/02/09 02:40 AM
04/02/09 02:40 AM
Florida STAYcation
Florida STAYcation
Hey CompSyn .... you speak well of the product ... just like anyone who has their hands in-the-profit pie of Amsoil sales.
How about a person like myself ....... that is just SKEPTICAL of the whole Amsoil "deal" ?
SKEPTICAL .... of just WHERE do all the combustion by-products go during the 25,000 miles that this oil is being used. Does this oil have some way to "magically" make these by-products disappear?
SKEPTICAL ..... that these sales people are just not up-front with everyone on WHY these Amsoil products are so expensive. SIMPLY .. because it is a multi-level-marketing program that it HAS to be that way ... because so many people in this pyramind have to make a profit.
Doublely SKEPTICAL .... since lots of these Amsoil advertising claims CLAIM that their product is so much better than the competition. Yet no independent proof is ever supplied.
And NO .... I am not talking about the infomercial like Prolong ....when they had Al Unser driving a Viper around a race-track with NO OIL in the motor at all. And then after an hour or so ... saying the motor was fine.
Well .... enough from me for now ... I have been up since 6am yesterday ....time to hit-the-hay .... but I will be-back.
Re: Question for Amsoil racing oil users [Re: dOoC] #272367
04/02/09 09:34 AM
04/02/09 09:34 AM
BradH Offline OP
BradH  Offline OP
No problem. But since I'm not an Amsoil "drone" and am simply trying to get answers to my questions, please stop posting on this thread.
If you have a need to start an Amsoil-specific debate, you should start your own thread. I'd be more than interested in reading it to see what comes of it.
Re: Question for Amsoil racing oil users [Re: dOoC] #272368
04/02/09 01:27 PM
04/02/09 01:27 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
You’re skeptical. That’s perfectly understandable. Unconventional claims can be intimidating. If anyone would like data to help address their reservations about this topic, feel free to ask.
For now, the question of combustion by-products keeps coming up. Below, a few related motor oil chemical component definitions.
Dispersant: A dispersing agent, which holds a very finely divided substance in a dispersed state in the carrier fluid. Such as sludge or a wear particles in a motor oil.
Detergency: The ability of an oil to keep working surfaces of equipment clean (i.e. free from contaminants) by holding oil-insoluble material in suspension thus preventing deposition where it would be harmful.
Total Base Number (TBN): The quantity of acid, expressed in terms of the number of milligrams that is required to neutralize all basic constituents present in one-gram sample. Otherwise known as ASTM Method D-644, D-974, or D-2896.
The above three chemical compounds are just a few of the items found in all modern day motor oils. These compounds of various grades and quantities are formulated into the finished product by formulators in order to meet current API – ILSAC specifications. Further, motor oil formulators have the ability to formulate their products with more or less of these compounds giving their products designability and proprietary characteristics.
For example compare the differences of TBN content in the popular motor oils below.
ClickHERE for a larger image.
Application: When a Used Oil Analysis UOA report comes back, TBN is often used to determine how long a motor oil can be used in the specific application it is utilized in. Note: A TBN value of one(1) on a UOA report is considered to be low.
This is just some of the story of how motor oils can be designed with extended life in mind.
CompSyn
