Re: Indy valve covers
[Re: cl440]
#272307
03/31/09 09:26 AM
03/31/09 09:26 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Looking to install the breathers that came with my header evac kit into our new Indy cast Aluminum covers. What is the best way to go? A rubber grommet with built in baffle? A screw in baffle?
We have done them with the grommets and they work find as long as you keep the hole tight and the fit good.Don't forget to baffel the breather.
[Re: cl440]
#272310
03/31/09 12:14 PM
03/31/09 12:14 PM
Posts: 1,890 In the 8's
FY1TA
In the 8's
I found these at Summit. I may try them
Thats what I put in mine and they work great .
[Re: cl440]
#272311
03/31/09 12:30 PM
03/31/09 12:30 PM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
If you decide to go with screw in baffles + rubber grommets, try OEM Mopar grommets PN 2946079 instead of the wimpy/thin generic aftermarket stuff. The OEM grommets are way better and they don't tear easily.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#272312
03/31/09 03:31 PM
03/31/09 03:31 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
Those grommets look HD! But I would then need to have a plate type baffle to screw to the underside of the Indy cover. Similar to my cast MP covers correct?
[Re: cl440]
#272313
03/31/09 03:59 PM
03/31/09 03:59 PM
ZIPPY
S.E. Michigan
Yep, will most likely need an add-on baffle. About the only bummer w/those grommets is the hole has to be opened up bigger than the generic 1.22-1.25 size. I forget the exact dimension but it's a skosh larger. But they're so much better than the generic aftermarket grommets it's worth it
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#272314
03/31/09 04:17 PM
03/31/09 04:17 PM
cl440
S.E. Michigan
Found a set on ebag and they say:
These grommets fit in a 1 1/2 inch hole in the valve cover. They have a 1 inch opening for the vent breather tube.
[Re: ZIPPY]
#272316
03/31/09 05:42 PM
03/31/09 05:42 PM
B G Racing
Eighty Four, PA
And the breathers stay put
[Re: B G Racing]
#272317
03/31/09 07:30 PM
03/31/09 07:30 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
The Summit bolt in style fit into a 1 3/8" hole, the same size as the Mopar grommet. I just replaced my Mopar grommets w the Summit style in my Indy Hemi Valve covers.
Be a Rebel- Break the Laws of Physics!
[Re: FY1TA]
#272321
04/02/09 09:47 PM
04/02/09 09:47 PM
cl440
S.E. Michigan
You should put a drop of locktite on them . One of mine came loose .
Yes, Good point. Thanks
[Re: nhramark]
#272323
04/03/09 09:18 AM
04/03/09 09:18 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
I used K&N breathers with the rubber in past but they leaked a bit and spit some oil drops every now and then. I then got 2 pieces of gaspipe w/ thread which I screwed in the covers. The K&N breathers happened to fit tight in these pipes without any lock or whatsoever. Still running it that way without any problems.
That summit solutions does look goo though...
