Indy valve covers #272305
03/31/09 09:12 AM
03/31/09 09:12 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Looking to install the breathers that came with my header evac kit into our new Indy cast Aluminum covers. What is the best way to go? A rubber grommet with built in baffle? A screw in baffle?
Re: Indy valve covers [Re: cl440] #272306
03/31/09 09:25 AM
03/31/09 09:25 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Screw in as the rubber ones leak and end up getting torn and such.
Re: Indy valve covers [Re: cl440] #272307
03/31/09 09:26 AM
03/31/09 09:26 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have done them with the grommets and they work find as long as you keep the hole tight and the fit good.Don't forget to baffel the breather.
Re: Indy valve covers [Re: B G Racing] #272308
03/31/09 09:32 AM
03/31/09 09:32 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I found these at Summit. I may try them
Re: Indy valve covers [Re: cl440] #272309
03/31/09 10:09 AM
03/31/09 10:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Loose the breathers and get a vacuum pump
Re: Indy valve covers [Re: cl440] #272310
03/31/09 12:14 PM
03/31/09 12:14 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Thats what I put in mine and they work great .
Re: Indy valve covers [Re: cl440] #272311
03/31/09 12:30 PM
03/31/09 12:30 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If you decide to go with screw in baffles + rubber grommets, try OEM Mopar grommets PN 2946079 instead of the wimpy/thin generic aftermarket stuff. The OEM grommets are way better and they don't tear easily.
Rich H.
Esse Quam Videri
Re: Indy valve covers [Re: ZIPPY] #272312
03/31/09 03:31 PM
03/31/09 03:31 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Those grommets look HD! But I would then need to have a plate type baffle to screw to the underside of the Indy cover. Similar to my cast MP covers correct?
Re: Indy valve covers [Re: cl440] #272313
03/31/09 03:59 PM
03/31/09 03:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, will most likely need an add-on baffle.
About the only bummer w/those grommets is the hole has to be opened up bigger than the generic 1.22-1.25 size. I forget the exact dimension but it's a skosh larger. But they're so much better than the generic aftermarket grommets it's worth it
Rich H.
Esse Quam Videri
Re: Indy valve covers [Re: ZIPPY] #272314
03/31/09 04:17 PM
03/31/09 04:17 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Found a set on ebag and they say:
These grommets fit in a 1 1/2 inch hole in the valve cover. They have a 1 inch opening for the vent breather tube.
Re: Indy valve covers [Re: cl440] #272315
03/31/09 05:23 PM
03/31/09 05:23 PM
Nebraska
Lime446 Offline
Lime446  Offline
Nebraska
I just got my valve covers back from Mark Martin aeicnc.com they did an awesome job BTW are indy covers and I've been wondering now what I'm going to do for baffle and breathers too.
Re: Indy valve covers [Re: ZIPPY] #272316
03/31/09 05:42 PM
03/31/09 05:42 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
And the breathers stay put
Re: Indy valve covers [Re: B G Racing] #272317
03/31/09 07:30 PM
03/31/09 07:30 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
The Summit bolt in style fit into a 1 3/8" hole, the same size as the Mopar grommet. I just replaced my Mopar grommets w the Summit style in my Indy Hemi Valve covers.
Be a Rebel- Break the Laws of Physics!
Re: Indy valve covers [Re: mbogina] #272318
03/31/09 09:24 PM
03/31/09 09:24 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Anyone know of a Oil Fill Setup that could be used without a bung being welded in? I also have Indy Covers but didn't put a provision in for the Oil Fill when the Vacuum Pump fittings were installed.
Re: Indy valve covers [Re: Bubba] #272319
04/02/09 09:05 PM
04/02/09 09:05 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Got the baffles from summit today. I have to say I am very impressed with them. They look great and seem to be very well designed. We installed them in the covers and all looks well! Hopefully we will have them "track tested" soon.
Re: Indy valve covers [Re: cl440] #272320
04/02/09 09:16 PM
04/02/09 09:16 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
You should put a drop of locktite on them . One of mine came loose .
Re: Indy valve covers [Re: FY1TA] #272321
04/02/09 09:47 PM
04/02/09 09:47 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Yes, Good point. Thanks
Re: Indy valve covers [Re: Lime446] #272322
04/03/09 08:38 AM
04/03/09 08:38 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Glad you are happy with them Dustin!
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Indy valve covers [Re: nhramark] #272323
04/03/09 09:18 AM
04/03/09 09:18 AM
Netherlands
72Challenger Offline
Netherlands
I used K&N breathers with the rubber in past but they leaked a bit and spit some oil drops every now and then. I then got 2 pieces of gaspipe w/ thread which I screwed in the covers. The K&N breathers happened to fit tight in these pipes without any lock or whatsoever. Still running it that way without any problems.
That summit solutions does look goo though...
Re: Indy valve covers [Re: 72Challenger] #272324
04/23/09 09:38 AM
04/23/09 09:38 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Baffles worked good. Didn't suck or leak any oil on our 4 test passes.
