440 Aluminum water pump housing? #2715254
11/12/19 09:17 PM
11/12/19 09:17 PM
USA
Lawn Monkey Offline OP
USA
Whats to know about 440 aluminum water pump housings? I think I want one, are they a direct fit . I'd like a USA made housing , any suggestions?
Re: 440 Aluminum water pump housing? [Re: Lawn Monkey] #2715274
11/12/19 09:55 PM
11/12/19 09:55 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Yo Monk .....don’t thimk there’s a USA housing anymore....direct fit ? Depends on what your combo is
Re: 440 Aluminum water pump housing? [Re: Lawn Monkey] #2715312
11/12/19 11:54 PM
11/12/19 11:54 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
The ports are smaller inside than a stocker.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: 440 Aluminum water pump housing? [Re: pishta] #2715321
11/13/19 01:18 AM
11/13/19 01:18 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
In some cases, that was true.
440Source did have a run of rough castings that had the smaller internal passages but they have improved them since then.
One thing to make a note of:
The thermostat sits higher on the aluminum housings by 5/8". This can interfere with the fitment of the A/C compressor if you are considering an aftermarket Classic Auto Air kit with the small Sanden compressor.
Re: 440 Aluminum water pump housing? [Re: Jjs72D] #2715331
11/13/19 04:44 AM
11/13/19 04:44 AM
USA
USA
Combo or fitment is just a basic 1970 440 came out of an old Chrysler New Yorker. In the 70's if I remember correctly these aluminum water pump housings were 200 dollars from Direct Connection , I find them easily on ebay 78 dollars and up . The low ebay prices makes me wonder if they're are of a good decent quality confused
Re: 440 Aluminum water pump housing? [Re: Lawn Monkey] #2715332
11/13/19 05:19 AM
11/13/19 05:19 AM
USA
USA
This one in the link is made in South Korea , it looks good, do y'all think it will fit and keep my engine cool?
https://www.ebay.com/itm/360942088722?ul_noapp=true
Re: 440 Aluminum water pump housing? [Re: Lawn Monkey] #2715481
11/13/19 06:28 PM
11/13/19 06:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
They work great.
6000 + miles on my 505" RB.
Hundreds of dragstrip passes.
Never any issues using the stock '65 radiator and factory clutch fan.
Takes 600 hp and a 200 shot of nitrous like a Walrus takes to water!
'63 Dodge 330
11.19 @ 121 mph
Re: 440 Aluminum water pump housing? [Re: MikeyT] #2716034
11/15/19 10:10 AM
11/15/19 10:10 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Any idea how much weight the aluminum water pump housing saves?
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 440 Aluminum water pump housing? [Re: 67SATisfaction] #2716132
11/15/19 03:45 PM
11/15/19 03:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
- Art
8 lbs. as I recall.
'63 Dodge 330
11.19 @ 121 mph
Re: 440 Aluminum water pump housing? [Re: GY3] #2716141
11/15/19 04:25 PM
11/15/19 04:25 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
MP was the last seller that I am aware of, for USA origin B/RB water pump housings.
The last place they were made was the same California facility that also cast and machined the M1 intake manifold line.
All gone now.
The older Direct Connection housings are cast pretty roughly and are a little bit thin compared to the MP pieces. I don't know where
they were cast as that was before my time, but it had to have been from different tools than the last MP housings.
Rich H.
Esse Quam Videri
