Re: 440 Aluminum water pump housing?
[Re: Lawn Monkey]
#2715312
11/12/19 11:54 PM
11/12/19 11:54 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
The ports are smaller inside than a stocker.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: pishta]
#2715321
11/13/19 01:18 AM
11/13/19 01:18 AM
Posts: 1,235 Phoenix, AZ
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
The ports are smaller inside than a stocker. In some cases, that was true. 440Source did have a run of rough castings that had the smaller internal passages but they have improved them since then. One thing to make a note of: The thermostat sits higher on the aluminum housings by 5/8". This can interfere with the fitment of the A/C compressor if you are considering an aftermarket Classic Auto Air kit with the small Sanden compressor.
[Re: Lawn Monkey]
#2715481
11/13/19 06:28 PM
11/13/19 06:28 PM
Posts: 4,669 Wichita
GY3
Wichita
They work great.
6000 + miles on my 505" RB.
Hundreds of dragstrip passes.
Never any issues using the stock '65 radiator and factory clutch fan.
Takes 600 hp and a 200 shot of nitrous like a Walrus takes to water!
[Re: MikeyT]
#2716034
11/15/19 10:10 AM
11/15/19 10:10 AM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Any idea how much weight the aluminum water pump housing saves? - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#2716132
11/15/19 03:45 PM
11/15/19 03:45 PM
GY3
Wichita
Any idea how much weight the aluminum water pump housing saves? - Art 8 lbs. as I recall.
[Re: GY3]
#2716141
11/15/19 04:25 PM
11/15/19 04:25 PM
Posts: 17,842 S.E. Michigan
ZIPPY
S.E. Michigan
MP was the last seller that I am aware of, for USA origin B/RB water pump housings. The last place they were made was the same California facility that also cast and machined the M1 intake manifold line.
All gone now.
The older Direct Connection housings are cast pretty roughly and are a little bit thin compared to the MP pieces. I don't know where they were cast as that was before my time, but it had to have been from different tools than the last MP housings.
Rich H.
Esse Quam Videri
