cam swap for street/resto 416 sb
#2713678
11/07/19 01:26 PM
11/07/19 01:26 PM
Posts: 1,795 BC Canada
ogopogo
BC Canada
I have a 340 stroker (416) here going into a 71 cuda restoration car,car is 4 speed with 355 gears and will be running stock manifolds and OE exhaust.For some unknown reason former owner has a solid tappet cam in this engine so I have to pull that out and install a hydraulic camshaft. I have 2 comp hyd flat tapppets here I can use: https://www.summitracing.com/parts/cca-20-214-4/or https://www.summitracing.com/int/parts/cca-20-224-4/overview/make/dodgeThis car will only be a driver/show car so I dont want it to sound like a race car but Im okay with slightly lopier than stock idle.......I'm also open to buying a new cam as well...
Re: cam swap for street/resto 416 sb
[Re: ogopogo]
#2713694
11/07/19 01:58 PM
11/07/19 01:58 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I'm building something very similar for a customer. Watching with enthusiasm. Was contemplating extrude honing the factory iron intake and exhaust manifolds however I've read that it doesn't yield much gain.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ogopogo]
#2713703
11/07/19 02:22 PM
11/07/19 02:22 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
For some unknown reason former owner has a solid tappet cam in this engine so I have to pull that out and install a hydraulic camshaft. What's wrong with a solid flat tappet cam? Why do you 'have to' pull it, is it too big for the combination? You don't say why specifically other than you prefer it not to sound like race car. You do have more cubic inches than stock...
'71 Duster '72 Challenger '17 Ram 1500
[Re: ogopogo]
#2713706
11/07/19 02:34 PM
11/07/19 02:34 PM
Posts: 4,457 Washington
madscientist
Washington
I have a 340 stroker (416) here going into a 71 cuda restoration car,car is 4 speed with 355 gears and will be running stock manifolds and OE exhaust.For some unknown reason former owner has a solid tappet cam in this engine so I have to pull that out and install a hydraulic camshaft. I have 2 comp hyd flat tapppets here I can use: https://www.summitracing.com/parts/cca-20-214-4/or https://www.summitracing.com/int/parts/cca-20-224-4/overview/make/dodgeThis car will only be a driver/show car so I dont want it to sound like a race car but Im okay with slightly lopier than stock idle.......I'm also open to buying a new cam as well... With what you are doing, I'd get ahold of Dwayne Porter and let him spec you a cam. It will be worth the time and effort. Stuffing 416 inches out exhaust manifolds is tricky to get correct. I just think an off the shelf cam will require you to accept too many compromises.
[Re: madscientist]
#2713713
11/07/19 03:02 PM
11/07/19 03:02 PM
ogopogo
BC Canada
What's wrong with a solid flat tappet cam? shruggy
Its a very valuable car and the clatter of non stock,incorrect solid lifters will devalue this car,it will be close to an OE restoration,former owner was doing a hot rod resto.....
[Re: ogopogo]
#2713742
11/07/19 03:50 PM
11/07/19 03:50 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I'm building a 410 SB now... almost ready to install into the car... from everything I've learned about cam selection for a SB stroker, the two cams you indicate are very small (especially duration, as well as lift).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: mopar dave]
#2713853
11/07/19 11:00 PM
11/07/19 11:00 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Do you know the compression ratio of the engine?
Brian Hafliger
[Re: ogopogo]
#2713922
11/08/19 11:07 AM
11/08/19 11:07 AM
RMCHRGR
Spahn Ranch
Its a very valuable car and the clatter of non stock,incorrect solid lifters will devalue this car,it will be close to an OE restoration,former owner was doing a hot rod resto..... Sorry but your reasoning for pulling the cam makes little sense since the shortblock is stroked. Seems pointless to me to go through all that work and go backwards in performance. If you don't care about making more power, why not pull the entire engine and rebuild it to stock stroke, '71 340 specs? Seems like that's what you're after and either of the cams you posted should work much better with less cubic inches.Proceeding that way would make more sense in the long run rather than trying to band-aid the situation with mis-matched parts. You're halfway there already if you pull the cam. You can re-use pretty much everything except the crank and pistons.Don't know what heads and induction you have but if you have aftermarket stuff you can sell those parts off and find the correct pieces. Not trying to spend your money but if you believe the car has more value with the OE combination it would stand to reason to do the job "correctly". Just a thought.
[Re: madscientist]
#2713974
11/08/19 01:38 PM
11/08/19 01:38 PM
Posts: 5,160 Texas
dannysbee
Texas
I have a 340 stroker (416) here going into a 71 cuda restoration car,car is 4 speed with 355 gears and will be running stock manifolds and OE exhaust.For some unknown reason former owner has a solid tappet cam in this engine so I have to pull that out and install a hydraulic camshaft. I have 2 comp hyd flat tapppets here I can use: https://www.summitracing.com/parts/cca-20-214-4/or https://www.summitracing.com/int/parts/cca-20-224-4/overview/make/dodgeThis car will only be a driver/show car so I dont want it to sound like a race car but Im okay with slightly lopier than stock idle.......I'm also open to buying a new cam as well... With what you are doing, I'd get ahold of Dwayne Porter and let him spec you a cam. It will be worth the time and effort. Stuffing 416 inches out exhaust manifolds is tricky to get correct. I just think an off the shelf cam will require you to accept too many compromises. ^ what he said. Might even consider a hydraulic roller.
Getting old just means you were smarter than some and luckier than others.
