I have a 340 stroker (416) here going into a 71 cuda restoration car,car is 4 speed with 355 gears and will be running stock manifolds and OE exhaust.For some unknown reason former owner has a solid tappet cam in this engine so I have to pull that out and install a hydraulic camshaft.
I have 2 comp hyd flat tapppets here I can use:
https://www.summitracing.com/parts/cca-20-214-4/or
https://www.summitracing.com/int/parts/cca-20-224-4/overview/make/dodgeThis car will only be a driver/show car so I dont want it to sound like a race car but Im okay with slightly lopier than stock idle.......I'm also open to buying a new cam as well...
