Disac brake safety wire? #270241
03/29/09 11:20 AM
03/29/09 11:20 AM
Q
Quicktree Offline OP
Q
how many of you actually use safety wire (ON THE BOLTS) on after market disc brakes?
Re: Disac brake safety wire? [Re: Quicktree] #270242
03/29/09 11:25 AM
03/29/09 11:25 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used it on the bolts that hold the rotor to the hub but no where else.
Re: Disac brake safety wire? [Re: Quicktree] #270243
03/29/09 11:49 AM
03/29/09 11:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I used it... the bolts were already drilled
Re: Disac brake safety wire? [Re: MR_P_BODY] #270244
03/29/09 11:55 AM
03/29/09 11:55 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
no way to use it on the Aerospace brakes I have so no I didnt use it
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Disac brake safety wire? [Re: Quicktree] #270245
03/29/09 11:59 AM
03/29/09 11:59 AM
Did not use wire. Used loctite on key bolts.
Car is drag race only. Check them twice a season
6 years later still no losey. Wilwood fronts
Re: Disac brake safety wire? #270246
03/29/09 12:15 PM
03/29/09 12:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
all my bolts was drill but did't use it..loc-tight them..if I was driving it on the street or road racing..I would of..drag race only..if I had the tool and wire here I might have ?
Re: Disac brake safety wire? [Re: VernMotor] #270247
03/29/09 12:52 PM
03/29/09 12:52 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Good insurance
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Disac brake safety wire? [Re: chryco] #270248
03/29/09 01:03 PM
03/29/09 01:03 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Mine are , had a friend that one of them backed out it had loctite on it too
Lucky for him , he was going down return road when the wheel locked up
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Disac brake safety wire? #270249
03/29/09 01:04 PM
03/29/09 01:04 PM
Q
Q
thats what I have always done. was just curious to what every body else does.
Re: Disac brake safety wire? [Re: Quicktree] #270250
03/29/09 03:19 PM
03/29/09 03:19 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I had one caliper mounting bolt come out, was red loctited too. Now I know why they're drilled.
Re: Disac brake safety wire? [Re: Bill MeLater] #270251
03/29/09 03:42 PM
03/29/09 03:42 PM
ALL my rear calipers are wired, its done for a reason when 1 starts loosening, they all start and then problems happen. Tony wire them up.
just get the correct wiring tool pliers, it makes things go smoothly and neat.
Re: Disac brake safety wire? #270252
03/29/09 04:47 PM
03/29/09 04:47 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I supost ? Jegs
safety wire pliers #555-82414 $29.99
safety wire #82410 $16.99
I wonder why wilwoods come lose and the areospace ones don't ?
Re: Disac brake safety wire? [Re: VernMotor] #270253
03/29/09 05:27 PM
03/29/09 05:27 PM
harbor freight safety wire pliers 6" $6.99 9" $9.99 and safety wire is $3.99 at a hardware store.
Re: Disac brake safety wire? [Re: VernMotor] #270254
03/29/09 05:34 PM
03/29/09 05:34 PM
Q
Q
I supost ? Jegs
I have never had a wilwood come loose with loctite and I have done many sets. but I may get the pliers and safety wire and do them later, it's one of them things there is always a first time.
Re: Disac brake safety wire? [Re: Quicktree] #270255
03/29/09 05:52 PM
03/29/09 05:52 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
One of them deals it only takes one time ! I never seen any come lose?
Re: Disac brake safety wire? [Re: VernMotor] #270256
03/29/09 06:33 PM
03/29/09 06:33 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have had two rotors come loose,we will be using wire from now on.
Re: Disac brake safety wire? [Re: Quicktree] #270257
03/29/09 08:08 PM
03/29/09 08:08 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yes.
Re: Disac brake safety wire? [Re: Leigh] #270258
03/29/09 08:16 PM
03/29/09 08:16 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just a tip on wiring stuff (I know most of you guys know)the wire should be ran from the side that tightens the bolt if you pull on the wire. So if you have 2 bolts one over the other and they're both right hand thread have the wire exit the right side of the top bolt, and enter the left side of the lower bolt. That way any tension on the wire tightens both bolts.
Re: Disac brake safety wire? [Re: VernMotor] #270259
03/29/09 08:37 PM
03/29/09 08:37 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I supost ? Jegs
Jamie, if you need it done let me know, I do it all the time at work and have the tool plus the stainless wire.
Re: Disac brake safety wire? [Re: dartman366] #270260
03/29/09 08:57 PM
03/29/09 08:57 PM
Q
Q
I supost ? Jegs
where were you when I needed you today?
