Re: Disac brake safety wire?
[Re: Quicktree]
#270242
03/29/09 11:25 AM
03/29/09 11:25 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used it on the bolts that hold the rotor to the hub but no where else.
[Re: MR_P_BODY]
#270244
03/29/09 11:55 AM
03/29/09 11:55 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
no way to use it on the Aerospace brakes I have so no I didnt use it
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Quicktree]
#270245
03/29/09 11:59 AM
03/29/09 11:59 AM
Did not use wire. Used loctite on key bolts. Car is drag race only. Check them twice a season 6 years later still no losey. Wilwood fronts
[Re: chryco]
#270248
03/29/09 01:03 PM
03/29/09 01:03 PM
Posts: 34,937 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Mine are , had a friend that one of them backed out it had loctite on it too
Lucky for him , he was going down return road when the wheel locked up
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
#270249
03/29/09 01:04 PM
03/29/09 01:04 PM
Quicktree
thats what I have always done. was just curious to what every body else does.
[Re: Bill MeLater]
#270251
03/29/09 03:42 PM
03/29/09 03:42 PM
I had one caliper mounting bolt come out, was red loctited too. Now I know why they're drilled.
ALL my rear calipers are wired, its done for a reason when 1 starts loosening, they all start and then problems happen. Tony wire them up. just get the correct wiring tool pliers, it makes things go smoothly and neat.
[Re: VernMotor]
#270253
03/29/09 05:27 PM
03/29/09 05:27 PM
harbor freight safety wire pliers 6" $6.99 9" $9.99 and safety wire is $3.99 at a hardware store.
[Re: VernMotor]
#270254
03/29/09 05:34 PM
03/29/09 05:34 PM
Quicktree
I supost ? Jegs
safety wire pliers #555-82414 $29.99
safety wire #82410 $16.99
I wonder why wilwoods come lose and the areospace ones don't ?
I have never had a wilwood come loose with loctite and I have done many sets. but I may get the pliers and safety wire and do them later, it's one of them things there is always a first time.
[Re: dartman366]
#270260
03/29/09 08:57 PM
03/29/09 08:57 PM
Quicktree
I supost ? Jegs
Jamie, if you need it done let me know, I do it all the time at work and have the tool plus the stainless wire.
where were you when I needed you today?
