Can you use stock rocker arms on Edelbrock heads #269673
03/28/09 04:35 PM
03/28/09 04:35 PM
Redding, CA
RDJ Offline OP
RDJ  Offline OP
Redding, CA
Can you use the stock (off of a 1984 360 head) rocker arms/shafts with the 60779 Edelbrock heads with a cam in 230 to 240 at .050 range? If so, is it commonly done?
Re: Can you use stock rocker arms on Edelbrock heads [Re: RDJ] #269674
03/28/09 04:51 PM
03/28/09 04:51 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Yes, but I would check you geometry, and use new arms, not worn pcs.
Re: Can you use stock rocker arms on Edelbrock heads [Re: moper] #269675
03/28/09 08:13 PM
03/28/09 08:13 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Sure, but as already stated, get new rocker arms if the ones you have are stock. Mancini sells stock style arms that are reinforced. They're pictured here of Eddie heads.
Re: Can you use stock rocker arms on Edelbrock heads [Re: MarkZ] #269676
03/28/09 08:23 PM
03/28/09 08:23 PM
tucson az
frank Offline
frank  Offline
tucson az
Yes. I use stock type arms on my 383 with Eddy heads. No problems. FYI, I read an article in on of the Mopar mags a few years ago about rocker arms. According to the article, the HD stock type rockers, were in fact no different than stock rockers.
Re: Can you use stock rocker arms on Edelbrock heads [Re: RDJ] #269677
03/28/09 09:20 PM
03/28/09 09:20 PM
Redding, CA
RDJ Offline OP
RDJ  Offline OP
Redding, CA
So, putting all the comments together, if the stock ones are new, they are no different than the HD ones Mancini sells (according to the Mopar mag article), and would work fine.
Re: Can you use stock rocker arms on Edelbrock heads [Re: RDJ] #269678
03/28/09 09:25 PM
03/28/09 09:25 PM
Redding, CA
RDJ Offline OP
RDJ  Offline OP
Redding, CA
Also, I was thinking maybe the adjustable 273 rocker arm assemblys might work. Anybody use one of those on eddy heads?
Re: Can you use stock rocker arms on Edelbrock heads [Re: RDJ] #269679
03/29/09 12:16 AM
03/29/09 12:16 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Not to highjack this post, but can the stock pushrods be used too?
Re: Can you use stock rocker arms on Edelbrock heads [Re: mopars4ever] #269680
03/29/09 03:38 AM
03/29/09 03:38 AM
Redding, CA
RDJ Offline OP
RDJ  Offline OP
Redding, CA
I would like to know also.
Re: Can you use stock rocker arms on Edelbrock heads [Re: RDJ] #269681
03/29/09 10:31 AM
03/29/09 10:31 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The old MP rockers were actually thicker thruout. You can see it in a side by side comparison. The newer MP and Mancini ones have some extra strength around the pushrod from the set I saw last year... It's not a thicker metal, but has some tiny ribs around the backside of the PR seat. I consider them stock arms myself, because they will still flex like mad and dont have the best ratio accuracy. AS far as pushrods, you can use any THAT ARE THE RIGHT LENGTH. When an engine is rebuilt properly, the distances between the rocker and the lifter are affected. So a stock part may be too long. The last part I order is always the pushrods and i use a checking one to measure for the right part. I have yet to need a custom length, but off-the-shelf shorter numbers are commonly used. You really should check. i'm not going to say stock will work because you should be changing (correcting to blueprint dimensions) too much. Decking, milling, smaller base circle cams, valve job quality all affect the pushrod length... But you may find a stock length does work.
Re: Can you use stock rocker arms on Edelbrock heads [Re: moper] #269682
03/29/09 01:40 PM
03/29/09 01:40 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i used both stock rockers and pushrods with eddy heads...
Tony
70 AARCuda Vitamin C
Re: Can you use stock rocker arms on Edelbrock heads [Re: 70AARcuda] #269683
03/29/09 02:10 PM
03/29/09 02:10 PM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
I built a 1968 383 with eddy heads used new rockers and push rods from PAW and the metal was thicker than the stock ones. the engine in the car did keep pushing the push rods threw the rockers . the new engine is in and rus great!!!
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
