Re: Can you use stock rocker arms on Edelbrock heads
[Re: RDJ]
#269674
03/28/09 04:51 PM
03/28/09 04:51 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Yes, but I would check you geometry, and use new arms, not worn pcs.
[Re: moper]
#269675
03/28/09 08:13 PM
03/28/09 08:13 PM
Posts: 4,432 Michigan
MarkZ
Worthy
Worthy
Sure, but as already stated, get new rocker arms if the ones you have are stock. Mancini sells stock style arms that are reinforced. They're pictured here of Eddie heads.
[Re: mopars4ever]
#269680
03/29/09 03:38 AM
03/29/09 03:38 AM
Posts: 47 Redding, CA
RDJ
Redding, CA
Not to highjack this post, but can the stock pushrods be used too?
I would like to know also.
[Re: RDJ]
#269681
03/29/09 10:31 AM
03/29/09 10:31 AM
moper
Columbia, CT
The old MP rockers were actually thicker thruout. You can see it in a side by side comparison. The newer MP and Mancini ones have some extra strength around the pushrod from the set I saw last year... It's not a thicker metal, but has some tiny ribs around the backside of the PR seat. I consider them stock arms myself, because they will still flex like mad and dont have the best ratio accuracy. AS far as pushrods, you can use any THAT ARE THE RIGHT LENGTH. When an engine is rebuilt properly, the distances between the rocker and the lifter are affected. So a stock part may be too long. The last part I order is always the pushrods and i use a checking one to measure for the right part. I have yet to need a custom length, but off-the-shelf shorter numbers are commonly used. You really should check. i'm not going to say stock will work because you should be changing (correcting to blueprint dimensions) too much. Decking, milling, smaller base circle cams, valve job quality all affect the pushrod length... But you may find a stock length does work.
[Re: moper]
#269682
03/29/09 01:40 PM
03/29/09 01:40 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
i used both stock rockers and pushrods with eddy heads...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#269683
03/29/09 02:10 PM
03/29/09 02:10 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
I built a 1968 383 with eddy heads used new rockers and push rods from PAW and the metal was thicker than the stock ones. the engine in the car did keep pushing the push rods threw the rockers . the new engine is in and rus great!!!
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
