Ported 915 iron heads flow #'s- Whatcha think
#267278
03/26/09 12:38 PM
03/26/09 12:38 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
I just got back a set of ported 915's that I bought used. I had them freshened up, while the shop had them they threw them on the bench. What do you think? Numbers are at 28" .100 IN 74.4 / EX 57.9 .200 IN 148.9/ EX 99.9 .300 IN 208.9/ EX 135.6 .400 IN 268.9/ EX 170.3 .500 IN 258.2/ EX 191.9 .600 IN 262.9/ EX 205.3 .700 IN 258.2/ EX 207 These heads going on zero deck, stock stroke 440 with MOPAR 590 solid cam, worked over M1 single plane intake, 850HP annular booster carb, and pro parts big tube headers. Any comments? What kind of power would you feel this would make?
Curator at Adams County Speed Shop
Re: Ported 915 iron heads flow #'s- Whatcha think
[Re: 340man4ever]
#267279
03/26/09 01:39 PM
03/26/09 01:39 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
You'll be looking at 450 - 460 HP. The heads are still going to be the cork in the system. I went from mildy ported 915's to Eddie RPM's out of the box and picked up 1/2 second. You've got plenty of cam and intake and well balanced carb. The duration of the cam should help the small ports, but just remember you aren't using it's full potential. What is your compression?
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: Mr.Yuck]
#267283
03/26/09 02:36 PM
03/26/09 02:36 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Those are some pretty good flowing 915's. That combo might make 550hp.
2 kids and a dog
[Re: TonyS451]
#267284
03/26/09 03:34 PM
03/26/09 03:34 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Almost exact same combo I went 11.42@118 in a 3800 lb. car threw muflers and with m&h street slicks. Jake
JAKES AUTOMOTIVE
[Re: JAKE68]
#267286
03/26/09 04:04 PM
03/26/09 04:04 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Almost exact same combo I went [Email]11.42@118[/Email] in a 3800 lb. car threw muflers and with m&h street slicks. Jake
I see alot of guys running this combo. My 65 Fury (4000 lbs) Line performance ported iron 452's. Ultradyne .590-.613 cam, 825 race Demon, M-1 intake, MSD, 440, car ran 11.16 at 118. Your combo should make well over 550 HP.
Snap your neck, mega G-force launch, is all I want!
[Re: 340man4ever]
#267288
03/26/09 08:52 PM
03/26/09 08:52 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
that combo should make 525-550hp easy.
[Re: fast68plymouth]
#267289
03/26/09 09:53 PM
03/26/09 09:53 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
FWIW - I had a 906's that had a flow sheet nearly identical to his and they went high 10.30s @ 128 on a TRW 440 shortblock with a small roller @ 3,240 lbs. In the dog summer days at Sac it would go .40's @ 127 like clockwork. Yea, it was a ladder bar car with a big tire, race converter, but the point is those "ol skool" heads did a good job.
With it hooking and a converter that's even close it should get in the 10's!
[Re: 340man4ever]
#267291
03/27/09 12:08 AM
03/27/09 12:08 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Wow, Almost the same combo I have run the last 3 years. I run a set of 915's which are not completely hogged out, but do have the 1.81 2.14 valves. Same cam, same intake, 750 annular discharge holley, trw 11.5 slugs on stock rods, crane 1.6 roller rockers. SS springs, leaving with a brake. 10.644 with 1.401 60 ft. 122 mph in a 3335 lb a-body. Enjoy the trouble free combo.
[Re: 383man]
#267293
06/09/10 12:44 AM
06/09/10 12:44 AM
340man4ever
Creston, Iowa
Update- took completed engine to Dave Bruns (Mid America Racing Engines, Washington Ia) shop and had motor broke in and dyno tested.
Threw a Wilson Manifolds tapered 1.5" combo spacer under the carb for the tests.
Best ignition timing was 38 total.
Motor made 561 HP at 6200. Best torque was 520 at 4900.
Threw a 1050 Dominator w/ shear plate and small phenolic spacer on it for kicks.
Motor made 565 Hp and 517 ft/lbs.
We used Sunoco 110 for fuel, NGK plugs gapped at .035, and FireCore 50 plug wires.
[Re: 340man4ever]
#267299
06/09/10 02:43 PM
06/09/10 02:43 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Numbers are at 28"
My comments, three things wrong, iron heads, Mopar 590 cam and annular boosters Is this a race only or dual duty motor and car? If it is a dual duty, be careful on the fuel, the iron close chamber heads will detonate very easily with the wrong fuel and tune up That being said I have used one of the older 590 cams one time , that motor had "346" heads and is still running in a bracket car after six or seven yaers of being race 5 to 15 times each year on race fuel good luck BTW, I saw the same results on that bracket motor on the engine dyno testing a Carb shop custom 1050 Dominator with a tapered dominator adapter against a BG 850 Street Demon on a TM7 intake, we later switch the intake to a 4500 Team G intake and a stock Holley 9375 1050 Dominator and saw a 30 HP increase with the Team G intake and no adapter
[Re: rook440]
#267303
06/10/10 01:18 AM
06/10/10 01:18 AM
340man4ever
Creston, Iowa
I started the engine build in 1978 LOL........ Flat tappet cams and iron heads will rise again....I can feel it............. Thanks for your help, support and friendship Rook Mr Looney
[Re: 340man4ever]
#267305
06/10/10 08:27 AM
06/10/10 08:27 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Yep, I'm excited to get going on our 318/390 Stroker Max Ported J-Heads, 11-1 Compression Tunnel Ram, Extremely Radical Hydraulic Flat Tappet Cam, 4-Speed
Rickster
