Ported 915 iron heads flow #'s- Whatcha think #267278
03/26/09 12:38 PM
03/26/09 12:38 PM
Creston, Iowa
3
340man4ever Offline OP
Creston, Iowa
I just got back a set of ported 915's that I bought used. I had them freshened up, while the shop had them they threw them on the bench. What do you think?
Numbers are at 28"
.100 IN 74.4 / EX 57.9
.200 IN 148.9/ EX 99.9
.300 IN 208.9/ EX 135.6
.400 IN 268.9/ EX 170.3
.500 IN 258.2/ EX 191.9
.600 IN 262.9/ EX 205.3
.700 IN 258.2/ EX 207
These heads going on zero deck, stock stroke 440 with MOPAR 590 solid cam, worked over M1 single plane intake, 850HP annular booster carb, and pro parts big tube headers. Any comments?
What kind of power would you feel this would make?
Curator at Adams County Speed Shop
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267279
03/26/09 01:39 PM
03/26/09 01:39 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
You'll be looking at 450 - 460 HP. The heads are still going to be the cork in the system. I went from mildy ported 915's to Eddie RPM's out of the box and picked up 1/2 second. You've got plenty of cam and intake and well balanced carb. The duration of the cam should help the small ports, but just remember you aren't using it's full potential. What is your compression?
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 67Charger] #267280
03/26/09 01:54 PM
03/26/09 01:54 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Im gonna say 525hp
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 67Charger] #267281
03/26/09 02:06 PM
03/26/09 02:06 PM
Creston, Iowa
3
Creston, Iowa
The compression will be 11.25:1
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267282
03/26/09 02:06 PM
03/26/09 02:06 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
good. I have 516's (2.14-1.81) They flow close to those... 260-190 I'll be running the 528 solid in a 440-6.
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: Mr.Yuck] #267283
03/26/09 02:36 PM
03/26/09 02:36 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Those are some pretty good flowing 915's. That combo might make 550hp.
2 kids and a dog
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: TonyS451] #267284
03/26/09 03:34 PM
03/26/09 03:34 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Almost exact same combo I went 11.42@118 in a 3800 lb. car threw muflers and with m&h street slicks. Jake
JAKES AUTOMOTIVE
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: JAKE68] #267285
03/26/09 03:54 PM
03/26/09 03:54 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
Thoes are good 915's. 915's are just not the greatest in this day and age as far as bang for the Buck (MHO). They'll be fine. I ran them on my 483 B stroker. MP 620 cam and a 950 Alky carb. They made power to about 5700 and peaked @ 550HP. TQ peaked @ 4000. Not enough head but run them if you got them.
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: JAKE68] #267286
03/26/09 04:04 PM
03/26/09 04:04 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Almost exact same combo I went [Email]11.42@118[/Email] in a 3800 lb. car threw muflers and with m&h street slicks. Jake
I see alot of guys running this combo. My 65 Fury
(4000 lbs) Line performance ported iron 452's.
Ultradyne .590-.613 cam, 825 race Demon, M-1 intake,
MSD, 440, car ran 11.16 at 118.
Your combo should make well over 550 HP.
Snap your neck, mega G-force launch, is all I want!
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: BDS871Cuda] #267287
03/26/09 04:44 PM
03/26/09 04:44 PM
Cumberland, MD
Supersonic Offline
Supersonic  Offline
Cumberland, MD
I have 915 heads on my dart, fully ported and polished, it ran a 10.38 @ 127 last fall. It ran the best shifting at 6, at 6500 it only ran 10.50's
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267288
03/26/09 08:52 PM
03/26/09 08:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
that combo should make 525-550hp easy.
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: fast68plymouth] #267289
03/26/09 09:53 PM
03/26/09 09:53 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
FWIW - I had a 906's that had a flow sheet nearly identical to his and they went high 10.30s @ 128 on a TRW 440 shortblock with a small roller @ 3,240 lbs. In the dog summer days at Sac it would go .40's @ 127 like clockwork. Yea, it was a ladder bar car with a big tire, race converter, but the point is those "ol skool" heads did a good job.
With it hooking and a converter that's even close it should get in the 10's!
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: cudadoug] #267290
03/26/09 10:51 PM
03/26/09 10:51 PM
Creston, Iowa
3
Creston, Iowa
The combustion chambers are presently 74cc giving me 11.25:1 compression. What kind of a gain would you anticipate if I milled them to bring it to 12:1. Would it be worth it? Would I be begging the heads to crack by doing that? Thanks in advance
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267291
03/27/09 12:08 AM
03/27/09 12:08 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Wow, Almost the same combo I have run the last 3 years. I run a set of 915's which are not completely hogged out, but do have the 1.81 2.14 valves. Same cam, same intake, 750 annular discharge holley, trw 11.5 slugs on stock rods, crane 1.6 roller rockers. SS springs, leaving with a brake. 10.644 with 1.401 60 ft. 122 mph in a 3335 lb a-body. Enjoy the trouble free combo.
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: fast68plymouth] #267292
03/27/09 02:12 AM
03/27/09 02:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with this. I run 906 heads I did some port work on myself on the mild 440 in my 63. I use the MP .557 cam and run 10.0 comp. That way it runs fine on 92 pump with the quench pad pistons I used. This has pushed my 3700 lb 63 to 11.50's @ 116 so far and I have yet to do any serious tunning on the car. I drive the car way more then I have raced it and the calculator I used says I push 475 to 500 hp so I see 525 to 550 in your combo. Go for it and have fun. Ron
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 383man] #267293
06/09/10 12:44 AM
06/09/10 12:44 AM
Creston, Iowa
3
Creston, Iowa
Update- took completed engine to Dave Bruns (Mid America Racing Engines, Washington Ia) shop and had motor broke in and dyno tested.
Threw a Wilson Manifolds tapered 1.5" combo spacer under the carb for the tests.
Best ignition timing was 38 total.
Motor made 561 HP at 6200. Best torque was 520 at 4900.
Threw a 1050 Dominator w/ shear plate and small phenolic spacer on it for kicks.
Motor made 565 Hp and 517 ft/lbs.
We used Sunoco 110 for fuel, NGK plugs gapped at .035, and FireCore 50 plug wires.
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267294
06/09/10 12:57 AM
06/09/10 12:57 AM
cudadoug Offline
cudadoug  Offline
Nevermind...
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267295
06/09/10 06:25 AM
06/09/10 06:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: JohnRR] #267296
06/09/10 06:43 AM
06/09/10 06:43 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
That's great! You may have to change your screen name now. Guess there is still a place for old school.
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: Joshs68] #267297
06/09/10 07:59 AM
06/09/10 07:59 AM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
Good job, that will be a good running motor!
