Leaking Warer Pump Bolt #2661050
05/31/19 08:51 PM
05/31/19 08:51 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Been awhile since I’ve worked on a Small block car with power steering. Problem I have the bolt that retains the adjustment for the power steering. Obviously this bolt goes into the water jacket in the block. What does everyone use to seal this type of bolt?
Abe Lincoln
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2661062
05/31/19 09:33 PM
05/31/19 09:33 PM
Indian Head cement in the brown bottle with the shoe polish type brush.
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2661077
05/31/19 10:44 PM
05/31/19 10:44 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Black rtv!
Re: Leaking Warer Pump Bolt [Re: moparpollack] #2661097
06/01/19 01:01 AM
06/01/19 01:01 AM
Phila
P
PhillyRag Online content
PhillyRag  Online Content
P
Phila
Originally Posted by moparpollack
Black rtv!
Permatex Aviation Sealer:
I personally stay away from rtv/silicones.
Have found too many "globs" of this stuff in Oil Pickup Screens & flushed some out of radiators.
Oil nor antifreeze doesn't dissolve it, once it breaks loose.
Re: Leaking Warer Pump Bolt [Re: PhillyRag] #2666141
06/15/19 10:14 AM
06/15/19 10:14 AM
Mesa, Arizona
Mesa, Arizona
Still fighting this bolt. Tried the aviation sealer, even used thread sealer. Still leaks a steady drip, drip ,drip. Maybe the bolt is too short not filling all the threads.
Abe Lincoln
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2666179
06/15/19 12:27 PM
06/15/19 12:27 PM
& you might get a new bolt (& check thread length engagement) for a slight bit better thread engagement. & someone who knows this stuff might recommend a bolt with a higher class of thread, there is a % #, not my area but you might Google or utube or call/visit a knowledgeable machinist. EDIT a steady drip on that area means something is seriously amiss, yes check the bolt thread length & worse case you might brake kleen the block threads & semipermanently seal a stud in there then do the looseneing with a nut on the outer end at the pump
Re: Leaking Warer Pump Bolt [Re: RapidRobert] #2666256
06/15/19 05:56 PM
06/15/19 05:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have used RTV before many times. Just don`t crazy with it. Also check the condition of the bolt , they get corroded pretty bad sometimes and yes, drain the coolant so the sealer gets a chance to dry.
Re: Leaking Warer Pump Bolt [Re: mopars4ever] #2666258
06/15/19 05:59 PM
06/15/19 05:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You are draining the water out and using an air blower or something to dry the hole out so the bolt with sealer goes into a dry hole.
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2666270
06/15/19 06:37 PM
06/15/19 06:37 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'm thinking longer or maybe try one with rolled threads??
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2666281
06/15/19 07:20 PM
06/15/19 07:20 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Hylomar blue.
Re: Leaking Warer Pump Bolt [Re: 135sohc] #2666320
06/15/19 08:34 PM
06/15/19 08:34 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Teflon tape works great, you can make it as thick or thin as you need it. It is impervious to oil, coolant, water, whatever. You can install it into a "wet" hole.
Be careful not to get too long a bolt if you go with a new one.
Since I don't have an LA car with power steering I am not sure which one you are referring to but it has been know for some hamfisted goons with too long a bolt to reef down on it and stress the #1 cylinder wall.
Re: Leaking Warer Pump Bolt [Re: Sniper] #2668625
06/22/19 09:14 AM
06/22/19 09:14 AM
Mesa, Arizona
Mesa, Arizona
This?
Abe Lincoln
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2668627
06/22/19 09:16 AM
06/22/19 09:16 AM
That be it. EDIT It used to be in a slightly different bottle, not sure what changed (if anything) formulawise. MORE EDIT pull the brush halfway out then press it sideways against the inside of the bottle to lose the excess then pull it out.
Re: Leaking Warer Pump Bolt [Re: RapidRobert] #2669127
06/23/19 08:06 PM
06/23/19 08:06 PM
Mesa, Arizona
Mesa, Arizona
Well, turns out it wasn’t the bolt. I totally cleaned off the area of the pump and blew it dry. Added a gallon of water and hit the area with air where it’s leaking. Water immediately started pooling at the base of the bypass hose. Brand new. Tightened up the clamp but only stems the leak for a bit. I’ll pickup another hose tomorrow. Talk about chasing my tail. panic
Abe Lincoln
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2669137
06/23/19 08:33 PM
06/23/19 08:33 PM
I'm glad it is an easy fix
Re: Leaking Warer Pump Bolt [Re: RapidRobert] #2669208
06/24/19 12:27 AM
06/24/19 12:27 AM
Mesa, Arizona
Mesa, Arizona
Me too. Thanks to all for the suggestions.
Abe Lincoln
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2669263
06/24/19 08:52 AM
06/24/19 08:52 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That assumes the hose was the problem and not a crack in the fitting/intake.
Ain't I full of pleasant thoughts?
Re: Leaking Warer Pump Bolt [Re: Sniper] #2669274
06/24/19 09:19 AM
06/24/19 09:19 AM
Mesa, Arizona
Mesa, Arizona
Not going to rule that out
Abe Lincoln
Re: Leaking Warer Pump Bolt [Re: dart4forte] #2669318
06/24/19 11:10 AM
06/24/19 11:10 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Reminds me of having the "rear main seal" changed, but still had a drip of oil . . . . was the oil sending unit, not tight enough !!! Oil down the side of the block and dripping out the bottom . . . . ughhhh . . .
Re: Leaking Warer Pump Bolt [Re: a12rag] #2669392
06/24/19 02:23 PM
06/24/19 02:23 PM
Mesa, Arizona
Mesa, Arizona
Oh yeah, had that happen
Abe Lincoln
