Leaking Warer Pump Bolt
#2661050
05/31/19 08:51 PM
05/31/19 08:51 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
Been awhile since I’ve worked on a Small block car with power steering. Problem I have the bolt that retains the adjustment for the power steering. Obviously this bolt goes into the water jacket in the block. What does everyone use to seal this type of bolt?
Abe Lincoln
Re: Leaking Warer Pump Bolt
[Re: dart4forte]
#2661062
05/31/19 09:33 PM
05/31/19 09:33 PM
RapidRobert
Indian Head cement in the brown bottle with the shoe polish type brush.
[Re: dart4forte]
#2661077
05/31/19 10:44 PM
05/31/19 10:44 PM
moparpollack
Lil Herman
Lil Herman
85086
[Re: moparpollack]
#2661097
06/01/19 01:01 AM
06/01/19 01:01 AM
Posts: 1,757 Phila
PhillyRag
Phila
Permatex Aviation Sealer: I personally stay away from rtv/silicones. Have found too many "globs" of this stuff in Oil Pickup Screens & flushed some out of radiators. Oil nor antifreeze doesn't dissolve it, once it breaks loose.
[Re: PhillyRag]
#2666141
06/15/19 10:14 AM
06/15/19 10:14 AM
dart4forte
Mesa, Arizona
Still fighting this bolt. Tried the aviation sealer, even used thread sealer. Still leaks a steady drip, drip ,drip. Maybe the bolt is too short not filling all the threads.
Abe Lincoln
[Re: dart4forte]
#2666179
06/15/19 12:27 PM
06/15/19 12:27 PM
RapidRobert
& you might get a new bolt (& check thread length engagement) for a slight bit better thread engagement. & someone who knows this stuff might recommend a bolt with a higher class of thread, there is a % #, not my area but you might Google or utube or call/visit a knowledgeable machinist. EDIT a steady drip on that area means something is seriously amiss, yes check the bolt thread length & worse case you might brake kleen the block threads & semipermanently seal a stud in there then do the looseneing with a nut on the outer end at the pump
[Re: dart4forte]
#2668627
06/22/19 09:16 AM
06/22/19 09:16 AM
RapidRobert
That be it. EDIT It used to be in a slightly different bottle, not sure what changed (if anything) formulawise. MORE EDIT pull the brush halfway out then press it sideways against the inside of the bottle to lose the excess then pull it out.
[Re: RapidRobert]
#2669208
06/24/19 12:27 AM
06/24/19 12:27 AM
dart4forte
Mesa, Arizona
I'm glad it is an easy fix Me too. Thanks to all for the suggestions.
Abe Lincoln
[Re: Sniper]
#2669274
06/24/19 09:19 AM
06/24/19 09:19 AM
dart4forte
Mesa, Arizona
That assumes the hose was the problem and not a crack in the fitting/intake.
Ain't I full of pleasant thoughts? Not going to rule that out
Abe Lincoln
[Re: a12rag]
#2669392
06/24/19 02:23 PM
06/24/19 02:23 PM
dart4forte
Mesa, Arizona
Reminds me of having the "rear main seal" changed, but still had a drip of oil . . . . was the oil sending unit, not tight enough !!! Oil down the side of the block and dripping out the bottom . . . . ughhhh . . . Oh yeah, had that happen
Abe Lincoln
