e-body headlight switch #2668743
06/22/19 03:14 PM
06/22/19 03:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
The only time that my instrument lights and parking lights come on is when I hold the headlight switch in between parking and headlights. But that is just before headlights come on. as soon as I move the switch far enough for headlights then no instrument or parking lights. I took apart the headlight switch and cleaned up all of the internal contacts. Still works exactly the same. I don't think it is a ground issue as all of the instrument and parking lights do work as long as I hold the headlight switch in one very small spot between parking and headlights. Any Ideas? Do i bite the bullet and buy a $150 rebuilt switch? or is there something else in play here that I am missing?
confused I am about ready to put the parking and instrument lights on a toggle switch.
Re: e-body headlight switch [Re: GomangoCuda] #2668746
06/22/19 03:22 PM
06/22/19 03:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A failed high beam switch can cause problems in the rest of the system, have you checked it?
Re: e-body headlight switch [Re: Alaskan_TA] #2668756
06/22/19 04:00 PM
06/22/19 04:00 PM
Well I just drove it last night. High and low beams worked as intended. Had to turn headlights off to see the instruments. Not so good. I actually did that a couple of times to take a quick peek at the Water Temp and Oil Pressure. Probably not the smartest thing I ever did. It was seriously dark at the time.
Re: e-body headlight switch [Re: GomangoCuda] #2668825
06/22/19 08:54 PM
06/22/19 08:54 PM
is there a cheaper HL switch you can purchase? (or a used one). I would feed 12V to each of the female terminals in the HL connector & see if every circuit responds normally. EDIT are E body switches unique?
Re: e-body headlight switch [Re: RapidRobert] #2668834
06/22/19 09:20 PM
06/22/19 09:20 PM
Yup.
Re: e-body headlight switch [Re: GomangoCuda] #2668835
06/22/19 09:22 PM
06/22/19 09:22 PM
LOL, that sure came out big.
Re: e-body headlight switch [Re: GomangoCuda] #2668911
06/23/19 02:07 AM
06/23/19 02:07 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Worn/Sloppy/Misaligned HL switch.
See pic.
When wiper B1 goes to HL position, wiper B2 moves to far off contact strip.
Or B1 wiper needs to move too far, & then B2 goes off contact.
Open it up again & re-inspect.
Re: e-body headlight switch [Re: PhillyRag] #2668955
06/23/19 09:09 AM
06/23/19 09:09 AM
can you drill out the rivets & open it up, likely an easy fix at that point.
Re: e-body headlight switch [Re: GomangoCuda] #2668965
06/23/19 09:44 AM
06/23/19 09:44 AM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Nope! Friends don't recommend friends to buy attempted rebuilt electrical Mopar parts on Ebay. Don't fall for those fake pictures.
Your switch can be RESTORED for a lot less and in a weeks turn around time.
Re: e-body headlight switch [Re: Slotts] #2669147
06/23/19 08:55 PM
06/23/19 08:55 PM
Missouri
randavis Offline
randavis  Offline
Missouri
Jim did a fantastic job on my e-body dash dimmer switch. I have pics to prove it.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: e-body headlight switch [Re: randavis] #2669337
06/24/19 12:13 PM
06/24/19 12:13 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
Another vote for Jim at JS Restorations. He did a great job on my dash dimmer switch also!
