e-body headlight switch
#2668743
06/22/19 03:14 PM
06/22/19 03:14 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
The only time that my instrument lights and parking lights come on is when I hold the headlight switch in between parking and headlights. But that is just before headlights come on. as soon as I move the switch far enough for headlights then no instrument or parking lights. I took apart the headlight switch and cleaned up all of the internal contacts. Still works exactly the same. I don't think it is a ground issue as all of the instrument and parking lights do work as long as I hold the headlight switch in one very small spot between parking and headlights. Any Ideas? Do i bite the bullet and buy a $150 rebuilt switch? or is there something else in play here that I am missing? I am about ready to put the parking and instrument lights on a toggle switch.
Re: e-body headlight switch
[Re: Alaskan_TA]
#2668756
06/22/19 04:00 PM
06/22/19 04:00 PM
GomangoCuda
Well I just drove it last night. High and low beams worked as intended. Had to turn headlights off to see the instruments. Not so good. I actually did that a couple of times to take a quick peek at the Water Temp and Oil Pressure. Probably not the smartest thing I ever did. It was seriously dark at the time.
[Re: GomangoCuda]
#2668825
06/22/19 08:54 PM
06/22/19 08:54 PM
RapidRobert
is there a cheaper HL switch you can purchase? (or a used one). I would feed 12V to each of the female terminals in the HL connector & see if every circuit responds normally. EDIT are E body switches unique?
[Re: PhillyRag]
#2668955
06/23/19 09:09 AM
06/23/19 09:09 AM
RapidRobert
can you drill out the rivets & open it up, likely an easy fix at that point.
[Re: GomangoCuda]
#2668965
06/23/19 09:44 AM
06/23/19 09:44 AM
Posts: 403 Pittsburgh, PA
Slotts
Pittsburgh, PA
Do i bite the bullet and buy a $150 rebuilt switch? Nope! Friends don't recommend friends to buy attempted rebuilt electrical Mopar parts on Ebay. Don't fall for those fake pictures. Your switch can be RESTORED for a lot less and in a weeks turn around time. Jim
[Re: Slotts]
#2669147
06/23/19 08:55 PM
06/23/19 08:55 PM
Posts: 144 Missouri
randavis
Missouri
Jim did a fantastic job on my e-body dash dimmer switch. I have pics to prove it.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: randavis]
#2669337
06/24/19 12:13 PM
06/24/19 12:13 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
Jim did a fantastic job on my e-body dash dimmer switch. I have pics to prove it. Another vote for Jim at JS Restorations. He did a great job on my dash dimmer switch also!
