rear end or suspension ckunk bang (video) #2667301
06/18/19 05:50 PM
06/18/19 05:50 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
See Video
https://youtu.be/qTqXb2wxJO0
Going from drive to reverse, the suspension wrap up. Even when shifting from 1-2 you can hear the bang sometimes.
Rear end?
Trans?
U joints seem tight
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: rear end or suspension ckunk bang (video) [Re: Kam*Kuda] #2667313
06/18/19 06:18 PM
06/18/19 06:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Seems like there is a good bit of free play in the ring and pinion adjustment. How much free play do you have in the rear end by turning the yoke back and forth with the trans in neutral?
Re: rear end or suspension ckunk bang (video) [Re: stumpy] #2667317
06/18/19 06:26 PM
06/18/19 06:26 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi kuda , also with it in neutral, lock up the e-brake, then check for excess backlash at yoke. does it have a "489" case ? wallowed/egged out cone case ? ronnie drive
Re: rear end or suspension ckunk bang (video) [Re: 1969ronnie] #2669961
06/25/19 09:24 PM
06/25/19 09:24 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
The good news is I think you can rule out needing to chase suspension problems. Something is definitely way off in the chunk as 1969Ronnie says.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: rear end or suspension ckunk bang (video) [Re: Michael Ecks] #2669964
06/25/19 09:34 PM
06/25/19 09:34 PM
NE
moparpoolman Offline
NE
The Pass side tire is moving quite a bit.
