rear end or suspension ckunk bang (video)
#2667301
06/18/19 05:50 PM
06/18/19 05:50 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
See Video https://youtu.be/qTqXb2wxJO0Going from drive to reverse, the suspension wrap up. Even when shifting from 1-2 you can hear the bang sometimes. Rear end? Trans? U joints seem tight
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: rear end or suspension ckunk bang (video)
[Re: 1969ronnie]
#2669961
06/25/19 09:24 PM
06/25/19 09:24 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
hi kuda , also with it in neutral, lock up the e-brake, then check for excess backlash at yoke. does it have a "489" case ? wallowed/egged out cone case ? ronnie The good news is I think you can rule out needing to chase suspension problems. Something is definitely way off in the chunk as 1969Ronnie says.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
