91 318 head gasket set. 16 o-rings? what for? #2660424
05/29/19 06:45 PM
05/29/19 06:45 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Hi all.
I have a 91 D150 and would like to change the valve seals this weekend. I may yank the heads if I don't have luck with my little valve spring compressor and air in the sparkplug hole to hold the valve up.
I ordered a headset apex brand AHS2060. It came with 16 o-rings and the felpro kit HS26179PT comes with them also.
Does anyone know what they are used for?
This is a TBI motor with normal LA shaft mounted rocker arms.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: 91 318 head gasket set. 16 o-rings? what for? [Re: CrAlt] #2660430
05/29/19 07:04 PM
05/29/19 07:04 PM
Guitar Jones Offline
They look like injector o rings. Doesn't matter that your engine doesn't use them. The aftermarket frequently gets things like this wrong.
Re: 91 318 head gasket set. 16 o-rings? what for? [Re: CrAlt] #2660436
05/29/19 07:19 PM
05/29/19 07:19 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would say Guitar is correct. that tbi 91 eng does not require such o-rings that would go above and below magnum port injectors, that you ain't got.
Re: 91 318 head gasket set. 16 o-rings? what for? [Re: buildanother] #2660438
05/29/19 07:29 PM
05/29/19 07:29 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Ya I think you guys are on to something with the MPI injectors. Probably cheaper to just toss them in then make a separate bag with out them.
I just hope the valve stem seals are the correct ones. I am used to seeing the older 2 different umbrella style ones for the E and I valves. These are all the same and look like they press on and latch on to the the valve guide.
Re: 91 318 head gasket set. 16 o-rings? what for? [Re: CrAlt] #2660450
05/29/19 08:14 PM
05/29/19 08:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That gasket kit is...interesting.
Injector O rings, headgaskets and plenum gasket for a Magnum.
Valve cover gaskets for an LA.
Re: 91 318 head gasket set. 16 o-rings? what for? [Re: Sniper] #2660469
05/29/19 09:03 PM
05/29/19 09:03 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Lol I didnt even notice the plenum gasket. I was just looking at the valve seals when I opened it.
The felpro kit doesn't come with the plenum but has the same headgaskets and o-rings. Apex and Felpro lists it as 1991 only. 318. I found a few photo's of the Felpro box and it says 1991 only. 89 and 92 are different sets.
confused
Screen Shot 2019-05-29 at 8.50.34 PM.pngScreen Shot 2019-05-29 at 8.50.49 PM.pngScreen Shot 2019-05-29 at 8.51.09 PM.pngSFL_HS26179PT_P04_TOP__ra_p.jpg
Re: 91 318 head gasket set. 16 o-rings? what for? [Re: CrAlt] #2661231
06/01/19 02:21 PM
06/01/19 02:21 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Well they are the right ones. thankfully wrench
