91 318 head gasket set. 16 o-rings? what for?
#2660424
05/29/19 06:45 PM
05/29/19 06:45 PM
Posts: 9,887 USA
CrAlt
USA
Hi all.
I have a 91 D150 and would like to change the valve seals this weekend. I may yank the heads if I don't have luck with my little valve spring compressor and air in the sparkplug hole to hold the valve up. I ordered a headset apex brand AHS2060. It came with 16 o-rings and the felpro kit HS26179PT comes with them also.
Does anyone know what they are used for?
This is a TBI motor with normal LA shaft mounted rocker arms.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: 91 318 head gasket set. 16 o-rings? what for?
[Re: CrAlt]
#2660430
05/29/19 07:04 PM
05/29/19 07:04 PM
Posts: 20,639 in a cattle trailer down by th...
Guitar Jones
They look like injector o rings. Doesn't matter that your engine doesn't use them. The aftermarket frequently gets things like this wrong.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: buildanother]
#2660438
05/29/19 07:29 PM
05/29/19 07:29 PM
Posts: 9,887 USA
CrAlt
USA
Ya I think you guys are on to something with the MPI injectors. Probably cheaper to just toss them in then make a separate bag with out them.
I just hope the valve stem seals are the correct ones. I am used to seeing the older 2 different umbrella style ones for the E and I valves. These are all the same and look like they press on and latch on to the the valve guide.
[Re: Sniper]
#2660469
05/29/19 09:03 PM
05/29/19 09:03 PM
Posts: 9,887 USA
CrAlt
USA
Lol I didnt even notice the plenum gasket. I was just looking at the valve seals when I opened it. The felpro kit doesn't come with the plenum but has the same headgaskets and o-rings. Apex and Felpro lists it as 1991 only. 318. I found a few photo's of the Felpro box and it says 1991 only. 89 and 92 are different sets.
