91 318 head gasket set. 16 o-rings? what for?
#2660424
05/29/19 06:45 PM
05/29/19 06:45 PM
Posts: 9,887 USA
CrAlt
USA
Hi all.
I have a 91 D150 and would like to change the valve seals this weekend. I may yank the heads if I don't have luck with my little valve spring compressor and air in the sparkplug hole to hold the valve up. I ordered a headset apex brand AHS2060. It came with 16 o-rings and the felpro kit HS26179PT comes with them also.
Does anyone know what they are used for?
This is a TBI motor with normal LA shaft mounted rocker arms.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: 91 318 head gasket set. 16 o-rings? what for?
[Re: CrAlt]
#2660430
05/29/19 07:04 PM
05/29/19 07:04 PM
Posts: 20,657 in a cattle trailer down by th...
Guitar Jones
They look like injector o rings. Doesn't matter that your engine doesn't use them. The aftermarket frequently gets things like this wrong.
[Re: buildanother]
#2660438
05/29/19 07:29 PM
05/29/19 07:29 PM
Posts: 9,887 USA
CrAlt
USA
Ya I think you guys are on to something with the MPI injectors. Probably cheaper to just toss them in then make a separate bag with out them.
I just hope the valve stem seals are the correct ones. I am used to seeing the older 2 different umbrella style ones for the E and I valves. These are all the same and look like they press on and latch on to the the valve guide.
[Re: Sniper]
#2660469
05/29/19 09:03 PM
05/29/19 09:03 PM
Posts: 9,887 USA
CrAlt
USA
Lol I didnt even notice the plenum gasket. I was just looking at the valve seals when I opened it. The felpro kit doesn't come with the plenum but has the same headgaskets and o-rings. Apex and Felpro lists it as 1991 only. 318. I found a few photo's of the Felpro box and it says 1991 only. 89 and 92 are different sets.
