Electric power brakes #2653903
05/10/19 03:54 AM
05/10/19 03:54 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Has anybody ever used electric power brake systems?
I have manual brakes on my car and perhaps want to convert to electric power brakes.
Re: Electric power brakes [Re: dickdale] #2653916
05/10/19 07:27 AM
05/10/19 07:27 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Never heard of such a thing, what application are you looking at?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Electric power brakes [Re: dickdale] #2653922
05/10/19 07:47 AM
05/10/19 07:47 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Only electric brakes I am aware of are for trailers. I have never seen any electric system for car brakes. There is hydro boost which runs off power steering pump. Usually for cars with low vacuum or turbo/super charger boosted cars that don't make vacuum. Or standard vacuum power booster. What car do you have?
All automotive brake systems (well, last 80 or so years) are hydraulic. That is,you push on pedal, it actuates a rod, and pushes a piston in the master cylinder. Fluid is then pushed to the wheels where the pressurized fluid pushes on small arms of a drum brake cylinder or actuates larger pistons in the caliper. For vacuum boost (or assist), pressing the pedal actuates a slider valve in a booster drum that uses vacuum to assist pushing on the rod that pushes the piston in the master cylinder. Electric trailer brakes use solenoids to push on the brake shoes. I don't recall seeing electric calipers.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Electric power brakes [Re: RoadRunner] #2653938
05/10/19 08:56 AM
05/10/19 08:56 AM
Guitar Jones Offline
I had not heard of this as a conversion before. Our hybrid cars use an electric booster type system, in fact the pedal isn't even hooked to anything but a module. However a simple google search reveals the truth. Still I would probably go with a hydraboost system before I would do this.
Electric power brake booster.
Re: Electric power brakes [Re: dickdale] #2653941
05/10/19 09:06 AM
05/10/19 09:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Gen Motors made some cars with vacuum boosted by elec pump on a certain few models back in the eighties or so.
Re: Electric power brakes [Re: buildanother] #2653957
05/10/19 09:58 AM
05/10/19 09:58 AM
moparx Offline
moparx  Offline
speedway, as well as others, have had the "electric" booster brake kit for a couple of years now. there is also an "electric" AC pump to keep you "kool" while you mash the brakes. biggrin
beer
Re: Electric power brakes [Re: dickdale] #2653999
05/10/19 11:47 AM
05/10/19 11:47 AM
Quote
what car/brakes? maybe we can assist in a different direction..
