Re: Electric power brakes
[Re: dickdale]
#2653922
05/10/19 07:47 AM
05/10/19 07:47 AM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Only electric brakes I am aware of are for trailers. I have never seen any electric system for car brakes. There is hydro boost which runs off power steering pump. Usually for cars with low vacuum or turbo/super charger boosted cars that don't make vacuum. Or standard vacuum power booster. What car do you have?
All automotive brake systems (well, last 80 or so years) are hydraulic. That is,you push on pedal, it actuates a rod, and pushes a piston in the master cylinder. Fluid is then pushed to the wheels where the pressurized fluid pushes on small arms of a drum brake cylinder or actuates larger pistons in the caliper. For vacuum boost (or assist), pressing the pedal actuates a slider valve in a booster drum that uses vacuum to assist pushing on the rod that pushes the piston in the master cylinder. Electric trailer brakes use solenoids to push on the brake shoes. I don't recall seeing electric calipers.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2653938
05/10/19 08:56 AM
05/10/19 08:56 AM
Posts: 20,639 in a cattle trailer down by th...
Guitar Jones
I had not heard of this as a conversion before. Our hybrid cars use an electric booster type system, in fact the pedal isn't even hooked to anything but a module. However a simple google search reveals the truth. Still I would probably go with a hydraboost system before I would do this. Electric power brake booster.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: dickdale]
#2653999
05/10/19 11:47 AM
05/10/19 11:47 AM
RapidRobert
I have manual brakes on my car what car/brakes? maybe we can assist in a different direction..
