Page 1 of 3 1 2 3
Spray bar valve cover #2652985
05/07/19 01:40 PM
05/07/19 01:40 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Hey guys it's been awhile since my last post.
I'm building wrench a spray bar set up for my 572-13 valve covers.
I plan on using 3/16 brake line. But one thing I can't
find any info on is what size holes to put in the spray
bar it self.
Can anyone help with that?
Needee luck
Re: Spray bar valve cover [Re: JoWeTu_6] #2653021
05/07/19 02:58 PM
05/07/19 02:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Divide the area of the line i.d by the number of holes and that will be the MAX area of the holes. Now use your math skills to convert that to a diameter and voila, you have your drill bit size. If the total area of the holes exceeds the area of the line size the oil will just dribble out, you needs the total area of the holes to be smaller to "squirt".
Re: Spray bar valve cover [Re: Stanton] #2653130
05/07/19 07:45 PM
05/07/19 07:45 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ok, will do panic LoL
I should be able to do that.
Thanx
Re: Spray bar valve cover [Re: JoWeTu_6] #2653138
05/07/19 08:26 PM
05/07/19 08:26 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ok, I think I have it using 3/16 brake line my calculations
have me using a numder 49 drill bit. boogie
Re: Spray bar valve cover [Re: JoWeTu_6] #2653161
05/07/19 09:23 PM
05/07/19 09:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is that with using the ID of the 3/16 tubing
wave
Re: Spray bar valve cover [Re: JoWeTu_6] #2653176
05/07/19 09:49 PM
05/07/19 09:49 PM
I have a set of spray bar V.C. that came with a set of Indy 440-1 heads that I bought that has Jesel paired shaft rocker arms on them, I tried to use my numbered drill bit set to see how big the holes are in them, a #60 bit was to big work Those lines are fed by a # 3 AN hose which is 3/16 I.D. I think
My wall chart shows a #60 bit to be .040 so the holes are smaller than that shruggy
I have another set of smaller numbered drill bits(61 to 80) in my race trailer but it is 45 miles away now with a customer car in it at a paint and body shop, I'm hoping I'll have it back by Friday to go race my car this weekend luck If you don't find out what size to use by then I will be glad to find out what size the holes are in mine up
Re: Spray bar valve cover [Re: Cab_Burge] #2653196
05/07/19 10:19 PM
05/07/19 10:19 PM
TEXAS
Panty Dropper Offline
TEXAS
Hey Guys,,, Just curious, but where can you purchase a set of BBM Valve covers already set up???
I am wanting to go with paired Rockers and get away from my T&D Shaft set up...]
Thanks in advance..
Re: Spray bar valve cover [Re: JoWeTu_6] #2653201
05/07/19 10:23 PM
05/07/19 10:23 PM
Get-X Offline
Get-X  Offline
The holes are extremely small. I believe they were like .015" on our B1 engine.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Spray bar valve cover [Re: JoWeTu_6] #2653340
05/08/19 10:52 AM
05/08/19 10:52 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Waaaaay too big. I'm not an expert on that but that size times 16. No.
2011 Drag Pak Challenger
Re: Spray bar valve cover [Re: rickseeman] #2653371
05/08/19 12:00 PM
05/08/19 12:00 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Imo, .012-.015 would be plenty big.
Re: Spray bar valve cover [Re: fast68plymouth] #2653405
05/08/19 02:02 PM
05/08/19 02:02 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
JFI . Both of the spray bar oil line kits we have used from Indy have had a restrictor in the T piece on the valve cover.
Re: Spray bar valve cover [Re: MR_P_BODY] #2653434
05/08/19 03:59 PM
05/08/19 03:59 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
No, ID. cool
Re: Spray bar valve cover [Re: JoWeTu_6] #2653436
05/08/19 04:03 PM
05/08/19 04:03 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Oooops I must have carried a 10 when I should
have droped a 5 some where. Thanx for the heads up
fellas. shruggy
I wouldn't have caught that thought it looked big but
I was giong with the numbers and they where wrong whiney
Re: Spray bar valve cover [Re: Tig] #2653438
05/08/19 04:06 PM
05/08/19 04:06 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ues I had planned on using a size .040 jet to restrict the oil
flow. confused
Re: Spray bar valve cover [Re: Cab_Burge] #2653443
05/08/19 04:22 PM
05/08/19 04:22 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ok , Cab it's been awhile since we spoke, Friday is fine
I'm in no hurry when it comes to getting it wright. stirthepot
Quick question you guys, I was just thinking with a spray bar set up
do I want them pointing at the push rods and adjusters or the rollers and
valve stems? shruggy
Re: Spray bar valve cover [Re: JoWeTu_6] #2653459
05/08/19 05:13 PM
05/08/19 05:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe that is already set for you on a spray bar.. but my way of thinking
is that it should be pointed at the adjusters and the stems.. the oil flows
down hill and will lube the rollers
wave
Re: Spray bar valve cover [Re: JoWeTu_6] #2653467
05/08/19 05:38 PM
05/08/19 05:38 PM
This Jesel set up does not oil the rockers at all, I'm using pushrod oiling also with the spray bars. The Jesel adjusters are hollow and allows the oil from the pushrods to blow right through it, no pressure oiling the shafts or any where else whiney
This is going to be one of my motors that will idle at or above 1500 RPM to insure plenty of splash oiling to the rocker arms and valve springs luck
Re: Spray bar valve cover [Re: Cab_Burge] #2653499
05/08/19 08:54 PM
05/08/19 08:54 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ok, kool. I guess I'll point the spray at the adjusters and hope
for some oil roll down to the rollers. I'll see how that works out. popcorn
Re: Spray bar valve cover [Re: JoWeTu_6] #2653598
05/09/19 08:42 AM
05/09/19 08:42 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I remember reading a comment that in a dead-end system (line enters cover at one end) most of the oil will go to the closest valve, and that to balance out the delivery the closest holes should be smallest, but how much?
Boffin Emeritus
Re: Spray bar valve cover [Re: polyspheric] #2653607
05/09/19 09:07 AM
05/09/19 09:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Nah. Before any oil can squirt out the line has to fill. Now, because the area of the holes is equal to or smaller than the feed line they will all squirt the same amount (or pretty damn close to it). I think the biggest issue will be drilling the holes and not leaving a burr inside the tube. Also, on all the Indy spray bars I've seen, the oil holes have a fairly wide chamfer on them - probably to widen the spray pattern.
Page 1 of 3 1 2 3
