Spray bar valve cover
#2652985
05/07/19 01:40 PM
05/07/19 01:40 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Hey guys it's been awhile since my last post. I'm building a spray bar set up for my 572-13 valve covers. I plan on using 3/16 brake line. But one thing I can't find any info on is what size holes to put in the spray bar it self. Can anyone help with that? Needee
Re: Spray bar valve cover
[Re: Stanton]
#2653130
05/07/19 07:45 PM
05/07/19 07:45 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Ok, will do LoL I should be able to do that. Thanx
[Re: JoWeTu_6]
#2653176
05/07/19 09:49 PM
05/07/19 09:49 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I have a set of spray bar V.C. that came with a set of Indy 440-1 heads that I bought that has Jesel paired shaft rocker arms on them, I tried to use my numbered drill bit set to see how big the holes are in them, a #60 bit was to big Those lines are fed by a # 3 AN hose which is 3/16 I.D. I think My wall chart shows a #60 bit to be .040 so the holes are smaller than that I have another set of smaller numbered drill bits(61 to 80) in my race trailer but it is 45 miles away now with a customer car in it at a paint and body shop, I'm hoping I'll have it back by Friday to go race my car this weekend If you don't find out what size to use by then I will be glad to find out what size the holes are in mine
[Re: JoWeTu_6]
#2653201
05/07/19 10:23 PM
05/07/19 10:23 PM
Posts: 614 Michigan
Get-X
The holes are extremely small. I believe they were like .015" on our B1 engine.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: JoWeTu_6]
#2653340
05/08/19 10:52 AM
05/08/19 10:52 AM
Posts: 2,685 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Ok, I think I have it using 3/16 brake line my calculations have me using a numder 49 drill bit. Waaaaay too big. I'm not an expert on that but that size times 16. No.
2011 Drag Pak Challenger
[Re: fast68plymouth]
#2653405
05/08/19 02:02 PM
05/08/19 02:02 PM
Posts: 2,937 A shed in England
Tig
A shed in England
JFI . Both of the spray bar oil line kits we have used from Indy have had a restrictor in the T piece on the valve cover.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: JoWeTu_6]
#2653436
05/08/19 04:03 PM
05/08/19 04:03 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Oooops I must have carried a 10 when I should have droped a 5 some where. Thanx for the heads up fellas. I wouldn't have caught that thought it looked big but I was giong with the numbers and they where wrong
[Re: Cab_Burge]
#2653443
05/08/19 04:22 PM
05/08/19 04:22 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Ok , Cab it's been awhile since we spoke, Friday is fine I'm in no hurry when it comes to getting it wright. Quick question you guys, I was just thinking with a spray bar set up do I want them pointing at the push rods and adjusters or the rollers and valve stems?
[Re: JoWeTu_6]
#2653459
05/08/19 05:13 PM
05/08/19 05:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok , Cab it's been awhile since we spoke, Friday is fine I'm in no hurry when it comes to getting it wright. Quick question you guys, I was just thinking with a spray bar set up do I want them pointing at the push rods and adjusters or the rollers and valve stems? I believe that is already set for you on a spray bar.. but my way of thinking is that it should be pointed at the adjusters and the stems.. the oil flows down hill and will lube the rollers
[Re: JoWeTu_6]
#2653598
05/09/19 08:42 AM
05/09/19 08:42 AM
Posts: 4,213 New York
polyspheric
New York
I remember reading a comment that in a dead-end system (line enters cover at one end) most of the oil will go to the closest valve, and that to balance out the delivery the closest holes should be smallest, but how much?
Boffin Emeritus
[Re: polyspheric]
#2653607
05/09/19 09:07 AM
05/09/19 09:07 AM
Posts: 8,914 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I remember reading a comment that in a dead-end system (line enters cover at one end) most of the oil will go to the closest valve, and that to balance out the delivery the closest holes should be smallest, but how much? Nah. Before any oil can squirt out the line has to fill. Now, because the area of the holes is equal to or smaller than the feed line they will all squirt the same amount (or pretty damn close to it). I think the biggest issue will be drilling the holes and not leaving a burr inside the tube. Also, on all the Indy spray bars I've seen, the oil holes have a fairly wide chamfer on them - probably to widen the spray pattern.
