Fuel pressure? #2650011
04/28/19 09:09 PM
04/28/19 09:09 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
What fuel pressure does a 5.7 Hemi need? I need to buy a pump for my 64 wagon to 5.7 Hemi conversion. I can't mount an in-tank pump, so I'll have to mount one on the frame as close to the tank as possible. But, I need to know the pressure requirement before I order one. Thanks.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Fuel pressure? [Re: rattler] #2650025
04/28/19 09:45 PM
04/28/19 09:45 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I run ~58psi on my stock injectors.
Any chance you can clear an Aeromotive Phantom kit? We installed one on a plastic D100 tank, which has no aftermarket tank support and it works very well!
Most any ~200-340lph EFI pump will have no problem running the average V8. I'd do everything I could to avoid an external pump, however.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Fuel pressure? [Re: GoodysGotaCuda] #2650243
04/29/19 03:04 PM
04/29/19 03:04 PM
IL
furious70 Offline
furious70  Offline
IL
In a decade of EFI use I've run an external Walbro 255 and it's been just fine. On an all day drive it does get a little loud but never left me stranded. 43psi.
*edit* 43psi is for my classic FAST controlled 383, not for a Gen III, should have made that clear.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Fuel pressure? [Re: furious70] #2650432
04/30/19 07:38 AM
04/30/19 07:38 AM
southwest Alabama
challenger73400 Offline
southwest Alabama
I had the same problem with my 58, not enough room for a efi pump to add to the top of the tank. I used a low pressure pump by the tank to feed a fitech command center 2 under the hood. The command center 2 runs 58 psi and continuously circulates fuel back to the tank. Oh, you have to add a return line.
Re: Fuel pressure? [Re: GoodysGotaCuda] #2650674
04/30/19 09:08 PM
04/30/19 09:08 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
The station wagon is stood on edge in the driver side quarter panel. So, no, there just isn't any room.
Re: Fuel pressure? [Re: challenger73400] #2651032
05/01/19 08:07 PM
05/01/19 08:07 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I can't remember, is there a return line coming off the fuel rails? If not how did you route a return line?
Re: Fuel pressure? [Re: rattler] #2651073
05/01/19 10:15 PM
05/01/19 10:15 PM
southwest Alabama
southwest Alabama
I ran a stainless supply and a return line down the inter passenger frame rail. The fitech kit came with a fitting to install the return into the tank.
Re: Fuel pressure? [Re: rattler] #2651074
05/01/19 10:30 PM
05/01/19 10:30 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Factory rails do not have a return fitting. It's not uncommon to run a regulator near the tank. That setup makes for some fluctuating fuel pressures, but it is at least consistent fluctuating that can be tuned to.
2020 RAM 1500
Re: Fuel pressure? [Re: GoodysGotaCuda] #2651202
05/02/19 12:33 PM
05/02/19 12:33 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
Hmmm,I have a 70 challenger doing a 5.7 hemi install,with a spectra efi tank,i was just about to add a return line to the car for the efi but its not needed? car has 5/16 stock fuel line,(340 car)
