I run ~58psi on my stock injectors.
Any chance you can clear an Aeromotive Phantom kit? We installed one on a plastic D100 tank, which has no aftermarket tank support and it works very well!
Most any ~200-340lph EFI pump will have no problem running the average V8. I'd do everything I could to avoid an external pump, however.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
