Re: Raising Rear Suspension
[Re: JFChallenger440]
#2644083
04/11/19 03:18 PM
04/11/19 03:18 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
What's involved and costs etc of raising the rear suspension on my 70 Satellite ? Want to get bigger tyres under there so only want to raise it a bit, thanks You might be able to take the front spring hanger and flip it upside down, effectively putting the leaf mount lower on the body, raising the car up a bit. However, the bolt pattern is not exactly symetrical from what i remember, so you can elongate the holes slightly to flip it. I believe the upper holes are slightly closer together than the lower ones. You can confirm by looking at the nuts on the front side to see pattern. I have done this very slight mod before with no problem. I dont remember how much height i gained, but maybe 3/4-1”.
#2644152
04/11/19 07:20 PM
04/11/19 07:20 PM
Posts: 11,082 Berlin, N.J.
abodyjoe
Berlin, N.J.
What's involved and costs etc of raising the rear suspension on my 70 Satellite ? Want to get bigger tyres under there so only want to raise it a bit, thanks call espo and get some +2" springs. should bring it up some.. http://www.springsnthings.com/
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: DaytonaTurbo]
#2644404
04/12/19 12:36 PM
04/12/19 12:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Even cheaper for longer shackles
But I wouldn't do that or helper springs either
[Re: Supercuda]
#2644511
04/12/19 07:39 PM
04/12/19 07:39 PM
Posts: 12,305 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What is wrong with using leaf type helper springs to raise the rear the little bit that the OP wants?
Master, again and still
[Re: DaveRS23]
#2644514
04/12/19 08:02 PM
04/12/19 08:02 PM
Supercuda
About to go away
About to go away
up yours
What is wrong with using leaf type helper springs to raise the rear the little bit that the OP wants? Because it's a crutch and the cheap ones make it handle squirrelly. .there are some areas you shouldn't cheap out on, brakes and suspension being in the top of that list
[Re: Supercuda]
#2644656
04/13/19 10:05 AM
04/13/19 10:05 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What is wrong with using leaf type helper springs to raise the rear the little bit that the OP wants? Because it's a crutch and the cheap ones make it handle squirrelly. .there are some areas you shouldn't cheap out on, brakes and suspension being in the top of that list To bash an entire product line based on the cheapest ones available is disingenuous. So how about the Hellwig brand of helper springs? They are American made, family owned, known for quality, and are not cheap. As for being 'a crutch', when properly applied, adding a half leaf helper is no more of a 'crutch' than adding a full leaf to a set of springs. Both are in reality helper springs. In fact, most of our Mopars came with half leafs from the factory. Those are essentially half leaf helpers. Proving that helper springs, when used correctly, most certainly have a place on our cars. Plus, the Hellwigs have the advantage of being adjustable. So what is wrong with adding a quality American made half leaf that is fully adjustable?
[Re: DaveRS23]
#2644658
04/13/19 10:10 AM
04/13/19 10:10 AM
Supercuda
About to go away
About to go away
up yours
Because someone saiod "cheapest way is helper springs" Pay attention.
But if you are going to piss away Hellwig money on helper springs just buy the new correct ones.
It's not rocket science.
[Re: Supercuda]
#2644699
04/13/19 11:24 AM
04/13/19 11:24 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Always with a caustic response.
Hellwigs are cheaper than a new set of springs, but are not cheap. Two different things there. And they are adjustable. And they will do exactly what the OP wants with no down side. And a new set of leaf springs is no guarantee that the OP will be any happier down the road. Plenty of threads here about that subject.
So why shouldn't the OP use quality adjustable leaf helper springs?
[Re: BlueRacer69]
#2644733
04/13/19 01:08 PM
04/13/19 01:08 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
This is just a thought and I'll probably take heat for saying this, but what about a set of Monroe air shocks for around $70 or $80 bucks. Air shocks would be my first choice too, however..... a good inspection of the upper mounts would be required. They're only sheet metal and not really designed to hold up the car so if they're not in good shape it would be a crap shoot. Generally speaking air shocks and Mopars don't mix well for that reason. I put Monroe's on my '64 Polara Super Stock recreation, but I also heavily reinforced the upper shock mounts by welding in a 2"x 2" square .120 wall crossmember. Works well too.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: forphorty]
#2644746
04/13/19 01:50 PM
04/13/19 01:50 PM
Chargerfan68
New York, USA
Flipping the stock front hangar will LOWER the car. Yes, you are absolutely right. My mistake. I have mp superstock hangers on my cars for the past 11 years or so, so i was relying on a picture of stock hangers when i answered. Sorry to the OP.
[Re: Chargerfan68]
#2644759
04/13/19 02:38 PM
04/13/19 02:38 PM
Posts: 15,946 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm sticking with my original answer. The right way to do it is new springs with additional leaf/leafs, or same number replacing worn ones. If that's "bashing" something, I'm sorry.
Facts are stubborn things.
