Raising Rear Suspension #2644070
04/11/19 02:56 PM
04/11/19 02:56 PM
London, England
JFChallenger440 Offline OP
London, England
What's involved and costs etc of raising the rear suspension on my 70 Satellite ? Want to get bigger tyres under there so only want to raise it a bit, thanks
Re: Raising Rear Suspension [Re: JFChallenger440] #2644079
04/11/19 03:07 PM
04/11/19 03:07 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
what rear suspension do you have? leaf spring, ladder bar, 4 link?
Re: Raising Rear Suspension [Re: JFChallenger440] #2644083
04/11/19 03:18 PM
04/11/19 03:18 PM
New York, USA
Chargerfan68 Offline
New York, USA
You might be able to take the front spring hanger and flip it upside down, effectively putting the leaf mount lower on the body, raising the car up a bit. However, the bolt pattern is not exactly symetrical from what i remember, so you can elongate the holes slightly to flip it. I believe the upper holes are slightly closer together than the lower ones. You can confirm by looking at the nuts on the front side to see pattern. I have done this very slight mod before with no problem. I dont remember how much height i gained, but maybe 3/4-1”.
Re: Raising Rear Suspension [Re: Chargerfan68] #2644112
04/11/19 04:49 PM
04/11/19 04:49 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Mancini has hangers with 2 positions, not sure if one is stock and one is lower or higher.
https://www.manciniracing.com/maraspha.html
Re: Raising Rear Suspension [Re: challenger70] #2644131
04/11/19 06:13 PM
04/11/19 06:13 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
You will get very little lift by repositioning that front hanger. I don't know how much more clearance you're looking for, but if only very little, like MAYBE 1/2" or less, you might get that from the front hanger. But I think you're really going to have to spring (haha) for the cost of new leafs with added leafs to get significant lift. twocents
Facts are stubborn things.
Re: Raising Rear Suspension [Re: JFChallenger440] #2644152
04/11/19 07:20 PM
04/11/19 07:20 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
call espo and get some +2" springs. should bring it up some.. http://www.springsnthings.com/
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Raising Rear Suspension [Re: Chargerfan68] #2644158
04/11/19 07:37 PM
04/11/19 07:37 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Flipping the stock front hangar will LOWER the car.
Re: Raising Rear Suspension [Re: JFChallenger440] #2644306
04/12/19 08:50 AM
04/12/19 08:50 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Here is a recent thread on this subject. The search function is your friend.
https://board.moparts.org/ubbthread...e-need-more-rear-spring.html#Post2623641
Master, again and still
Re: Raising Rear Suspension [Re: DaveRS23] #2644382
04/12/19 11:45 AM
04/12/19 11:45 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Cheapest would be to get a helper leaf spring and add it in to your existing leaf spring pack. Some guys even get junkyard springs and add a leaf to their existing springs. Better would be to have your springs re-arced or replace them with aftermarket but that would be more expensive.
Re: Raising Rear Suspension [Re: DaytonaTurbo] #2644404
04/12/19 12:36 PM
04/12/19 12:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Even cheaper for longer shackles
But I wouldn't do that or helper springs either
Don't be the exception.
Re: Raising Rear Suspension [Re: Supercuda] #2644511
04/12/19 07:39 PM
04/12/19 07:39 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What is wrong with using leaf type helper springs to raise the rear the little bit that the OP wants?
Re: Raising Rear Suspension [Re: DaveRS23] #2644512
04/12/19 07:43 PM
04/12/19 07:43 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Somebody original resto numbers guy will point it out somewhere along the line... shruggy
...FAFO...
Re: Raising Rear Suspension [Re: DaveRS23] #2644514
04/12/19 08:02 PM
04/12/19 08:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Because it's a crutch and the cheap ones make it handle squirrelly.
.there are some areas you shouldn't cheap out on, brakes and suspension being in the top of that list
Re: Raising Rear Suspension [Re: Supercuda] #2644656
04/13/19 10:05 AM
04/13/19 10:05 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
To bash an entire product line based on the cheapest ones available is disingenuous.
So how about the Hellwig brand of helper springs? They are American made, family owned, known for quality, and are not cheap. As for being 'a crutch', when properly applied, adding a half leaf helper is no more of a 'crutch' than adding a full leaf to a set of springs. Both are in reality helper springs. In fact, most of our Mopars came with half leafs from the factory. Those are essentially half leaf helpers. Proving that helper springs, when used correctly, most certainly have a place on our cars. Plus, the Hellwigs have the advantage of being adjustable.
So what is wrong with adding a quality American made half leaf that is fully adjustable?
Re: Raising Rear Suspension [Re: DaveRS23] #2644658
04/13/19 10:10 AM
04/13/19 10:10 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Because someone saiod "cheapest way is helper springs" Pay attention.
But if you are going to piss away Hellwig money on helper springs just buy the new correct ones.
It's not rocket science.
Re: Raising Rear Suspension [Re: JFChallenger440] #2644694
04/13/19 11:16 AM
04/13/19 11:16 AM
BlueRacer69 Offline
BlueRacer69  Offline
This is just a thought and I'll probably take heat for saying this, but what about a set of Monroe air shocks for around $70 or $80 bucks.
Re: Raising Rear Suspension [Re: Supercuda] #2644699
04/13/19 11:24 AM
04/13/19 11:24 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Always with a caustic response.
Hellwigs are cheaper than a new set of springs, but are not cheap. Two different things there. And they are adjustable. And they will do exactly what the OP wants with no down side. And a new set of leaf springs is no guarantee that the OP will be any happier down the road. Plenty of threads here about that subject.
So why shouldn't the OP use quality adjustable leaf helper springs?
Re: Raising Rear Suspension [Re: BlueRacer69] #2644733
04/13/19 01:08 PM
04/13/19 01:08 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Air shocks would be my first choice too, however..... a good inspection of the upper mounts would be required. They're only sheet metal and not really designed to hold up the car so if they're not in good shape it would be a crap shoot. Generally speaking air shocks and Mopars don't mix well for that reason.
I put Monroe's on my '64 Polara Super Stock recreation, but I also heavily reinforced the upper shock mounts by welding in a 2"x 2" square .120 wall crossmember. Works well too.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Raising Rear Suspension [Re: forphorty] #2644746
04/13/19 01:50 PM
04/13/19 01:50 PM
New York, USA
New York, USA
Yes, you are absolutely right. My mistake. I have mp superstock hangers on my cars for the past 11 years or so, so i was relying on a picture of stock hangers when i answered. Sorry to the OP.
Re: Raising Rear Suspension [Re: Chargerfan68] #2644759
04/13/19 02:38 PM
04/13/19 02:38 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I'm sticking with my original answer. The right way to do it is new springs with additional leaf/leafs, or same number replacing worn ones. If that's "bashing" something, I'm sorry.
