Race prepped 727 #2640471
04/02/19 11:29 PM
04/02/19 11:29 PM
New York, USA
Chargerfan68 Offline OP
New York, USA
Just curious what determines what gear the burnout should be started in? Is it the valve body, or the other internals? I have a nicely modded tranny from a reputable builder here and im not sure at all what internal mods have been done, except for a griner valve body that i saw when i dropped the pan for service. Its a reverse manual valve body. I will call them to ask specifics, but i fear that since i dont have any detailed paperwork on it, they might not be able to tell me what i want to know. I just see on paperwork: Pro-comp build and max hp rating 650hp.
Any general insight would be helpful.
Thx
Re: Race prepped 727 [Re: Chargerfan68] #2640490
04/03/19 02:15 AM
04/03/19 02:15 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
I think it depends on if it is a Low Band Apply or not.On a non LBA,if doing a burnout in 1st gear and something breaks it could damage the tranny.
On my '73 I do my burnouts in 3rd gear, 3.91 gears 295/55/15 tire.
john
Re: Race prepped 727 [Re: Chargerfan68] #2640515
04/03/19 08:55 AM
04/03/19 08:55 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It's built to handle 650 hp is a pretty broad statement IMO. In a 2700# or 3700# car? It makes a difference. I'd just start the burn out in second then move to high, there shouldn't be any issues that way.
Re: Race prepped 727 [Re: justinp61] #2640591
04/03/19 11:26 AM
04/03/19 11:26 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Main thing as I understand it is to never back out of the throttle in 1st. Beats the bejeezus out of the sprag.
Years ago in my ignorance I started burnouts in 1st, quickly shifting up; wasn't enough wheel speed for a good burnout anyway.
Re: Race prepped 727 [Re: topside] #2640597
04/03/19 11:34 AM
04/03/19 11:34 AM
A727Tflite Online content
A727Tflite  Online Content
None of the OE manufacturers rate their transmissions by horsepower, only torque.
Wonder why.
Re: Race prepped 727 [Re: topside] #2640598
04/03/19 11:35 AM
04/03/19 11:35 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Never in 1st. Period. My routine was to drop it into 2nd right after pulling out of the lanes and before it even went into the water. I also would not putt around in the pits in low gear. Trans was in low gear from after the burnout to the 1-2 shift, period. Even when we were using the 3 speed throttle stop racing. 1st gear to leave, immediately to second on a timer, run the stop all in second. Worked..
Re: Race prepped 727 [Re: CMcAllister] #2640638
04/03/19 01:00 PM
04/03/19 01:00 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Be thankful you have a manuel valve body. I've seen several trans. blow doing first gear burn out. Some with severe foot and leg injures. Second gear burn outs only, be aware before going into the water box to be in second.
Re: Race prepped 727 [Re: merpar] #2641079
04/04/19 10:30 AM
04/04/19 10:30 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
I know this all too well,i never trust a 727,no matter who builds it
Re: Race prepped 727 [Re: dart games] #2641088
04/04/19 10:50 AM
04/04/19 10:50 AM
More times than not it’s the drivers fault.
Re: Race prepped 727 [Re: A727Tflite] #2641104
04/04/19 11:15 AM
04/04/19 11:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree.. you can NOT pedal the car when in low gear.. shift it.. I
have been racing a 727 since I could drive and never had a explosion
and seldom ever need a rebuild.. drive it right and it works great..
dont pedal so you load and unload and load the sprag.. thats
a killer
wave
Re: Race prepped 727 [Re: MR_P_BODY] #2641111
04/04/19 11:30 AM
04/04/19 11:30 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
"Never trust it" is a little harsh. Like anything else - Use the right components, maintain it properly, drive it correctly and it will be fine.
Re: Race prepped 727 [Re: CMcAllister] #2641388
04/04/19 11:41 PM
04/04/19 11:41 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I’ll admit I typically start my burnouts in 1st, but just to get the tires moving then immediately through 2nd to D. I run an LBA valvebody. No problems so far.
