Race prepped 727
#2640471
04/02/19 11:29 PM
04/02/19 11:29 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Just curious what determines what gear the burnout should be started in? Is it the valve body, or the other internals? I have a nicely modded tranny from a reputable builder here and im not sure at all what internal mods have been done, except for a griner valve body that i saw when i dropped the pan for service. Its a reverse manual valve body. I will call them to ask specifics, but i fear that since i dont have any detailed paperwork on it, they might not be able to tell me what i want to know. I just see on paperwork: Pro-comp build and max hp rating 650hp. Any general insight would be helpful. Thx
Re: Race prepped 727
[Re: topside]
#2640598
04/03/19 11:35 AM
04/03/19 11:35 AM
Posts: 11,733 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never in 1st. Period. My routine was to drop it into 2nd right after pulling out of the lanes and before it even went into the water. I also would not putt around in the pits in low gear. Trans was in low gear from after the burnout to the 1-2 shift, period. Even when we were using the 3 speed throttle stop racing. 1st gear to leave, immediately to second on a timer, run the stop all in second. Worked..
[Re: A727Tflite]
#2641104
04/04/19 11:15 AM
04/04/19 11:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
More times than not it’s the drivers fault. I agree.. you can NOT pedal the car when in low gear.. shift it.. I have been racing a 727 since I could drive and never had a explosion and seldom ever need a rebuild.. drive it right and it works great.. dont pedal so you load and unload and load the sprag.. thats a killer ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2641111
04/04/19 11:30 AM
04/04/19 11:30 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
"Never trust it" is a little harsh. Like anything else - Use the right components, maintain it properly, drive it correctly and it will be fine.
[Re: CMcAllister]
#2641388
04/04/19 11:41 PM
04/04/19 11:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I’ll admit I typically start my burnouts in 1st, but just to get the tires moving then immediately through 2nd to D. I run an LBA valvebody. No problems so far.
