Back Half, exhaust under the axle #2639417
03/31/19 11:19 PM
03/31/19 11:19 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I'm considering going Larson Style with exhaust under the axle. Any real world experience appreciated. Option 2 is dump in front of the rear tire, Option 3 under the car in front of the axle. wink
https://www.youtube.com/watch?v=BawfQJ84aAY
Re: Back Half, exhaust under the axle [Re: gsmopar] #2639420
03/31/19 11:26 PM
03/31/19 11:26 PM
California
slowfab Offline
slowfab  Offline
California
I did it to my Cuda. I was reluctant to do it but worked out good. The key I think is to be sure the rear end does not drop down that far so the tubes do not need to hang low.
Re: Back Half, exhaust under the axle [Re: gsmopar] #2639453
04/01/19 12:45 AM
04/01/19 12:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
I had to have mine run under the rear axle on my old pump gas Duster, it helped hide the ladder bars due to the pipes coming directly out of the collector on the Hooker BB fenderwell headers and running straight back under the rocker panels like side pipes and then ducking around and under the rear tires and rear end with the muffs mounted behind the rear end housing between the sub frames and the outside 1/4 panels work devil up
Re: Back Half, exhaust under the axle [Re: Cab_Burge] #2639461
04/01/19 01:29 AM
04/01/19 01:29 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
We did that on a number of cars. Especially with big tubes, 4bar suspension, car lowered, fuel system plumbing, brake lines, you get the picture. Works great. As said, have to pay attention to how far the axle can drop. If you’re not running leafs, you can still curl the pipes out and do a dump at the back of the quarter panels.
Re: Back Half, exhaust under the axle [Re: CMcAllister] #2639499
04/01/19 08:28 AM
04/01/19 08:28 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
HEMI Joel has this type of exhaust on his Drag Week Coupe. Made it easy to remove the exhaust, and reinstall it for the drives. I could have it all off in under 10 minutes, and reinstalled in 15.
69 GTX 68 Road Runner
Re: Back Half, exhaust under the axle [Re: JERICOGTX] #2639666
04/01/19 01:05 PM
04/01/19 01:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sooooo much easier and nicer results. Not banging against the bottom of the car, use big pipes easily. TIG up some mandrel bends and it looks good. Especially in stainless.
Re: Back Half, exhaust under the axle [Re: CMcAllister] #2639825
04/01/19 07:27 PM
04/01/19 07:27 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have them on my Cuda, they work fine but as said you need to watch axle tube clearance, on the street mine is fine but on the strip it would hit and unload the tire.
1963 Plymouth Max Wedge
1971 Barracuda
