Re: Back Half, exhaust under the axle
[Re: Cab_Burge]
#2639461
04/01/19 01:29 AM
04/01/19 01:29 AM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We did that on a number of cars. Especially with big tubes, 4bar suspension, car lowered, fuel system plumbing, brake lines, you get the picture. Works great. As said, have to pay attention to how far the axle can drop. If you’re not running leafs, you can still curl the pipes out and do a dump at the back of the quarter panels.
[Re: CMcAllister]
#2639499
04/01/19 08:28 AM
04/01/19 08:28 AM
Posts: 10,028 MN
JERICOGTX
MN
HEMI Joel has this type of exhaust on his Drag Week Coupe. Made it easy to remove the exhaust, and reinstall it for the drives. I could have it all off in under 10 minutes, and reinstalled in 15.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2639666
04/01/19 01:05 PM
04/01/19 01:05 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sooooo much easier and nicer results. Not banging against the bottom of the car, use big pipes easily. TIG up some mandrel bends and it looks good. Especially in stainless.
[Re: CMcAllister]
#2639825
04/01/19 07:27 PM
04/01/19 07:27 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have them on my Cuda, they work fine but as said you need to watch axle tube clearance, on the street mine is fine but on the strip it would hit and unload the tire.
1963 Plymouth Max Wedge 1971 Barracuda
