E85? #2636683
03/24/19 10:15 PM
03/24/19 10:15 PM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
What is the max compression you can run with E85?
Thanks for any and all info
Kevin
Re: E85? [Re: 604 Hemi GTX] #2636686
03/24/19 10:24 PM
03/24/19 10:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
About 15:1.. I was running 14.1:1 in my 408ci
wave
Re: E85? [Re: MR_P_BODY] #2636708
03/24/19 10:47 PM
03/24/19 10:47 PM
ONTARIO,CANADA
ONTARIO,CANADA
So did you run E85 from the pump or buy VP, Renegade..... brand?
Kevin
Re: E85? [Re: 604 Hemi GTX] #2636714
03/24/19 11:02 PM
03/24/19 11:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought it from Meijer's by the 55 gal drum (pump)
wave
Re: E85? [Re: MR_P_BODY] #2636740
03/25/19 12:11 AM
03/25/19 12:11 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
In my new E85 engine configuration I'm running 11.5 with a blower. I will be using pump stuff. I have to buy a bunch at a time because the nearest pump is 86 miles. Don't have any results yet but I'm hopeful.
Re: E85? [Re: Blucuda413] #2636762
03/25/19 05:30 AM
03/25/19 05:30 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I buy it buy the drum(e-98) and mix to e-85,compression is 13.1.
Re: E85? [Re: 604 Hemi GTX] #2636950
03/25/19 12:53 PM
03/25/19 12:53 PM
My bracket 400 stroker 505 C.I. motor is right at 15.0 to 1, I use the local pump E85 and check it for the actual percentages, they vary from 85 % all the way up to 89 percent after sitting in the plastic fuel jugs in the race car trailer shruggy
I'm getting ready to go dyno test and break in the new bracket motor this week and I'll use the fuel in the jugs left over from last year, I'll check it and maybe I'll jet it up to see if I can get it rich enough to loose power luck
The first time I dyno a motor I bought E85 from the same station in early fall six years ago, they had ordered winter fuel that ended up testing to be 75% shock
All the fuel I've bought from them since then has tested to be 85% up
I have found that my bracket motor does NOT like cold spark plugs shock shruggy
Re: E85? [Re: Cab_Burge] #2637004
03/25/19 03:28 PM
03/25/19 03:28 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
been using it for many years now in our 3 bracket cars...buy it from the same station a couple miles from home. Always tests at 85% and there is no winter blend in las vegas.
Tony
70 AARCuda Vitamin C
Re: E85? [Re: 604 Hemi GTX] #2637010
03/25/19 03:45 PM
03/25/19 03:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The max compression based on when will it knock?
This isn't always the goal, some engines with large diameter chamber (hemi) will need a huge dome to get a really big static CR, and max power won't pick up beyond a certain point depending on bore, stroke, rod ratio. The dome obstructs flame travel and flow through during overlap.
Boffin Emeritus
Re: E85? [Re: polyspheric] #2637112
03/25/19 08:09 PM
03/25/19 08:09 PM
ONTARIO,CANADA
ONTARIO,CANADA
Another question is it as corrosive as alcohol?
Kevin
Re: E85? [Re: 604 Hemi GTX] #2637116
03/25/19 08:19 PM
03/25/19 08:19 PM
Kevin
Not as corrosive as straight Methanol due to some of the additives in it but it will corrode uncoated aluminum if you let it sit very long whiney shruggy
Re: E85? [Re: Cab_Burge] #2637588
03/27/19 07:59 AM
03/27/19 07:59 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
VP C85 is a great fuel. 2 of my cars run on it, one roots blown, the other nitrous.
I leave it in the fuel system even over the winter with no issues. C85 has some good corrosion inhibitors, and makes more power than any canned 85 I've tried. Doesn't sweat up the motor like pump either. There is a yellowish, oily residue left in the manifold, and runners. I'm guessing it's the inhibitor, but whatever it is, there is no rust anywhere in the bores. Running meth, or pump E85 I'd always see rust at the top of the bores where the rings don't reach. The tuning window is wider than gas.
